blackbelt308
I've seen a couple of different methods described to create a recessed port for an electrosocket, but this one worked so well for me that I thought I'd post it here for other builders. I'm in the midst of building four guitars (one Tele, three Jazzmasters) using a chambered "clamshell" approach, and I wanted to recess the electrosockets, especially for the Jazzmasters as I was planning for a side-mounted output jack rather than on the pickguard. Hope this is useful to you!
Used a Rockler self-centering doweling jig to drill a 1/4" pilot hole at the desired location. Body clamped to my bench, jig in place...
I considered other, cheaper jigs (e.g. from Amazon) but decided to spend a bit more for the Rockler jig. I think it was a good decision... This thing rocks! I didn't drill too deeply as I wanted to make sure that the arbor pilot would still have something to bite.
Spot-on centered pilot hole!
I used a 1" hole saw with a 1/4" piloted arbor to create the outer shelf for the electrosocket. This is best done at very low speed... You don't want to go too deep, and you don't want to tear up the wood. Practice several times on scrap before you try this on your precious guitar body!
Looks good so far!
Next, switch to a 7/8" hole saw on the same arbor to drill the main hole...
There we go! Lightly sand with 220 to clean up the edges.
Electrosocket in place! Just what I had in mind!
This worked very well for all four bodies. The Tele body had a flat spot for the output jack, but the Jazzmaster bodies I built were rounded so recessing the electrosocket was really key to getting a good look for those projects!
Ciao!
Rick
Looks good so far!
Ciao!
Rick
