REALLY, REALLY, microphonic neck pickup
Discussion in 'Just Pickups' started by Boreas, Oct 13, 2021.
  1. Boreas
    Boreas Poster Extraordinaire
    Adirondack Coast, NY
    I just strung up a new partscaster I built for a friend and after I got it playing, I kept hearing this "ping" when I hit the neck pickup cover with my pick. It is NOT subtle. The pickup sounds fine, but I don't recall it being this microphonic in its original home - a recent Squier Bullet. What I DID do when I swapped it to the new tele is set it up with a 4-way switch. I cut/removed the tiny ground wire and ran a ground wire to the cover, and installed normally.
    Is my memory bad and I forgot how microphonic it was, or is there something in grounding the cover that can cause this? The pickups sound great, but I tend to play and strum a lot over the neck pickup, and every time the plastic pick hits the cover, I know it. I tried lowering it as far as I can without much help. Any suggestions other than using another pickup? Are Bullet neck pickups particularly microphonic?
  2. Boreas
    BUMP. Any help?
  3. drf64
    drf64 Doctor of Teleocity
    Ada, MI
    If you are hitting it with your pick you need to back it down a turn or two
    Boreas likes this.
  4. Steve Holt
    Steve Holt Friend of Leo's
    Kansas
    Is it wax potted? If not potting isn't necessarily hard to do. Though there are some things to watch out for.
    Boreas likes this.
  5. telemnemonics
    Hmmm, maybe desoldering the ground from the tab that holds the cover on made the cover loose?
    Or maybe heating the solder point on the cover melted some potting wax and loosened up some of the coil?
    To me a pickup is deemed microphonic if it squeals.
    Most of mine make a noise through the amp if I tap on them.
  6. Timbresmith1
    Timbresmith1 Tele-Afflicted
    Central TX
    Some of the best Teles I’ve ever played were microphonic (you can yell near the pickup and it comes thru the amp) but didn’t squeal.
    gmm52, Boreas, guitar_paul1 and 2 others like this.
  7. telemnemonics
    I used to prefer the bridge be a bit microphonic, and would put them a little hotter so the hot wax mostly drained off, resulting in the pickup working as a crude mic if you yelled into it, yet the guitar was still playable with a 100w Marshall.
    Now it's less of a priority to ME but it is part of the Tele sound.
    chrisr0712, Boreas and Timbresmith1 like this.
  8. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    If tapping the pickup with a non-ferrous object creates that much noise, the pickup probably is microphonic. You can wax pot it yourself, or at least a home-grown version of it. I'd take the cover off and drip some candle wax inside it and around the pickup bobbin. Then hit it with some quick heat from a hair dryer when reassembling.
    It's not likely that you created the problem by soldering the extra ground wire, not unless you *really* applied too much heat with your soldering iron. Bullets are cheap and they don't spend much time on QC. You got one that snuck out with an imperfect pickup.
    Boreas likes this.
  9. guitar_paul1
    guitar_paul1 Tele-Holic
    washington state
    My actual 59 I had back in the 60s would squeal like a pig.
    Boreas likes this.
  10. Boreas
    Pretty low now. Starting to lose definition. The pick noise isn't the problem, it is a symptom
  11. Boreas
    So far I haven't got it to squeal, but I don't play very loud in the living room. This is being built for a friend who isn't likely to make 'er squeal either, but don't want to dump a problem on him.
    As I recall, it may have been pretty microphonic when I got it and that was part of my decision to replace them with Tex Mex pickups. I was also installing a Bigsby with a B-Blender so I wanted more oomph anyway. They have been in a drawer for a few years. The bridge pickup is fine. Both sound good, but I believe I need to potty train it. Just any old wax? Would stuffing foam or something under the metal cover help?
    Requisite pix.
  12. Addnine
    Addnine Tele-Holic
    New England
    On my Teisco, you can literally sing into the pickup and hear it through the amp. i really think that is part of the Teisco/goldfoil sound.
    thechad, Zepfan and Boreas like this.
  13. Boreas
    Yeah I used to have an old Silvertone (Harmony) with 3 foil pickups. Don't know why I dumped it. Well, I do - I Traded it and 2 other guitars toward a 1956 000-18 about 30 years ago.
    Addnine likes this.
  14. KokoTele
    Any old wax is fine. You’re just looking for something to dampen the vibrations, particularly in the coil. I don’t think you’ll find any foam that will work if it’s thin enough not to cause a problem fitting the cover.
    Boreas likes this.
  15. kiwi blue
    kiwi blue Tele-Afflicted
    Wellington, New Zealand
    Try putting a strip of double sided tape between the inside of the cover and the bobbin. Easier than messing with hot wax.
    Even easier, see whether the problem still happens when your friend plays it. Your friend's picking style may be different enough that they may not even hit the cover and it won't even be a problem.
    Boreas likes this.
  16. Boreas
    Thanks all! I am going to wax pot it. Something new for me. Probably do the bridge pickup too.
    I was just playing it and the the PING is so loud, it is as loud as a strongly strummed power chord.! It cuts right through the chord. Unbelievable. If I can figure out how to upload them, I might make a before and after recording.
    Actually, I am liking the guitar so much, I may give my friend a different one!
  17. Timbresmith1
    Central TX
    You can lacquer pot it. Not quite the down-dumbing of wax.
    Boreas likes this.
  18. Tom-Australia
    Tom-Australia Tele-Meister
    Transylvania
    I say leave it unpotted! Some great sounds to be had.
    Boreas likes this.
  19. SnidelyWhiplash
    SnidelyWhiplash Friend of Leo's
    Hoggtown, KY.
    Wax pot it. Easy to do & there are plenty of online tutorials on how to do so.
    Boreas likes this.
  20. Boreas
    Maybe I could use PlastiDip!
