Really Lightweight
Skip Ellis
I'm old with a bad back and need to build a Tele in the 5-6lb range - what wood would you suggest? Or would I be better off building something hollow or extremely chambered? I've built with Pauwlonia but find it hard to finish. Fortunately I have a local lumber supplier that stocks lots of 8/4 stock but all hardwoods. I've done all the above, just wanting to get suggestions from the hive mind. Attached is my last Pauwlonia surf Tele build.
trapdoor2
Sauth Carolina
I'm planning a hollow body. 2 F-hole thinline with a single Charlie Christian pup in the neck position. Might even glue the neck in (doubtful). Should be light!
I've never worried about neck dive.
peterg
Toronto
Guitar body wood doesn’t get much lighter than paulownia. Maybe use a wood lighter than maple for the neck and reduce the metal components? i.e. no neck pickup, body mounted bridge pickup, fixed strat bridge, rear loaded pots with a wood cover instead of a top loaded control plate, plastic knobs instead of metal.
Dan German
Left of the Left Coast
Balsa is a hardwood. Not suggesting you make a tele with it, just sayin’…
:p
Freeman Keller
One of the lightest woods that is used for solid body electrics is bass wood but it is terribly soft and you need to be aware denting it and screws not holding and finishing issues - frankly I would never build a guitar out of it.
What I would do, and I do this with almost every "solid body" guitar that I build is to chamber the heck out of it. MY personal tele-clone is made out of mahogany which is not particularly light wood, but the finished guitar weighs 5 pounds 12 oz. Everyone who playes it comments on the weight (or lack of0
guitarbuilder
Basswood is light -ish. but lacking a lot of character unless you put some oil on it. A million guitar bodies are made from it. Screws are not a problem unless you use the wrong size pilot hole or overtorque them. Basswood is low density but heavier than pawlownia, which I think is way too light myself. I used to use 1000 BF of basswood a year at my previous job.
One of my Vox like basswood bodies.
dkmw
Florida USA
Catalpa looks like ash, but can be lighter. It’s too bad that Clearfork Designs guy stopped his fleabay site. It seems he now supplies one of the “bigs”. Which he deserves, because his bodies were/are just about perfect.
Anyways, he had offered some catalpa that were under 3 lbs. So there are light pieces of that wood out there.
Bob J
Portland OR
I prefer a lighter guitar as well, and have either chambered or drilled all the bodies I’ve built to reduce weight. They typically end up in the 5 1/4 to 5 3/4 lb range. I tend to go for “woods of opportunity” (cheap or free or easily accessible), and so far they have been on the soft side (Doug Fir or pine for the core) but with a harder cap (ash or walnut). You can get pretty light if you’re willing to sacrifice other attributes.
gb Custom Shop
Winnipeg, Canada
I would suggest picking out some lumber you find pretty and chambering the body. Also, torrefied woods can often be ever so slightly lighter than non-torrefied woods (at least in my experience)
Geo
Hendersonville, TN
I bought a GFS paulownia body that came with a white finish. It was then lightly sanded and another paint color was sprayed
over it.
dogmeat
Alaska
5 pounds completed. as in completed with neck, pickups, and controls. may be a bit more, don't know but the scale did not say 6. made from an evilbay pawlaweenie wood body with a veneer. then hollowed out, then a 1/8" plywood back.
kifla
Houston, TX
Few months ago I've sold a handful o Jazzmaster bodies made out of spanish cedar
All were in the range between 1200 and 1300 grams....and Jazzy body is significantly larger than the Tele one
Nobody reported any issue with the wood.
hopdybob
netherlands
maybe something.
i have a old L6 copy full maple, and that is way thinner (3,3cm)and lighter than the others i have.
if you can combine this with the example of @Freeman Keller
use a headstock like
maybe you get what you want ;)
