Real or not?
Discussion in 'Telecaster Discussion Forum' started by Tesacque, Aug 11, 2019.
  1. Tesacque
    Tesacque TDPRI Member
    Denmark
    hi guys,
    I came across this guitar that was for sell for a very good price (around 400€). I got cold feet thinking it was not a us telecaster but still do not know and it is haunting me. Here are the pics.....
    Thanks for your help!
    It was labeled as a 1995 telecaster standard.
  2. ScottJPatrick
    ScottJPatrick Friend of Leo's
    Stirling, Scotland.
    not
    AlbertaGriff likes this.
  3. Chief101
    Chief101 Tele-Meister
    Not far from Nashville
    A poorly executed knockoff. Didn’t even try to get the decals right. Don’t waste your time.
    Clifton C and SecretSquirrel like this.
  4. urbandefault
    urbandefault Tele-Meister
    OKCUSA
  5. ScottJPatrick
    Stirling, Scotland.
    Looks more like a Squier standard with that finish, decals wrong and no walnut truss rod insert.
  6. ClashCityTele
    ClashCityTele Tele-Afflicted
    Washington, UK
    The decal on the back 'original contour body' is from a Strat.
    Cheap tuners.
    Avoid.
  7. Tesacque
    Denmark
    Thanks guys,
    This is what I thought! A squier turned into a us fender! Well, I guess I will have to wait a bit more before getting a US telecaster. At least, I can sleep now.
    I already have a telecaster fmt hh but would love a classic one.
    Thanks again for the heads up.
  8. El Tele Lobo
    El Tele Lobo Friend of Leo's Silver Supporter
    About as real as a $13 bill...
    Your cold feet did not lead you astray.
  9. jimilee
    jimilee Tele-Afflicted Silver Supporter
    Chattanooga
    I was gonna say, I had that squier once. Great guitar for 100.00 US.
  10. OzShadow
    OzShadow Tele-Meister Silver Supporter
    SE Michigan
    The serial number would be on the front too.
    SecretSquirrel likes this.
  11. vanr
    vanr Tele-Afflicted
    AZ
    Squier Standard Tele
  12. El Marin
    El Marin Tele-Afflicted
    Madrid, Spain, EU
    The "Contour body" decal is the key
    Fake
    DrPepper and SecretSquirrel like this.
  13. hemingway
    London, UK
    Do standards ever have 22 frets?
    DrPepper likes this.
  14. bullfrogblues
    bullfrogblues Friend of Leo's
    Southeast Florida
    The string ferrules on the back don't line up, either.
  15. archetype
    archetype Fiend of Leo's
    Williamsville NY
  16. Preacher
    Preacher Friend of Leo's
    Big D
    I see this question getting asked a lot on this forum, "is this legit?"
    See above an American Pro Tele.
    So to be able to spot a rebranded Squier...
    1) walnut plug at the truss rod. This is one of the most obvious items with a USA made Tele. Now I am sure there are some US Teles that don't have the walnut plug, but if it does have a walnut plug you are pretty safe that it is not a squier.
    2) string trees, most US Teles only use one string tree. And many times they look like the one pictured above but sometimes other bits are used. But if it has TWO string trees, be aware it might be a Squier.
    3) Decal - The Fender decal typically starts right behind the string tree. As in the case of the guitar shown earlier there is what looks like an inch between the string tree and the decal. Typical US teles are much closer. Also the "Telecaster" part of the decal starts at the notch in the head stock shape. On the mentioned picture above the "telecaster" is way toward the end of the head stock.
    4) Also note how far the first tuner is from the nut, squiers seem be a little further from the nut which I can only guess to be because of the break angle of the head stock, which may also be why they need two string trees.
    There are a number of other body issues you can check out as well. All in all it is just educating yourself on what parts to look for.
  17. Preacher
    Big D
    1999 USA Tele
    As you can see this one does not have the Walnut plug, but everything else matches up. This also shows the proper decal placement better than the last picture.
  18. Rufustelestrats
    Rufustelestrats Tele-Holic
    Banning, CA
    infamous wood chipper tele
  19. boris bubbanov
    New Orleans, LA + in the
    This is the second to last image, and it shows the 3 bottom bridge mount screws down at the very bottom of the plate. That's Squier or some other Import plate. The USA plate rather like this provides a fair amount of space between the bottom of the plate and those 3 screws. Plus, the USA Standards of that era have only 3 mount screws and nothing at either top corner.
    And finally, the "I see it from a mile away" marker is, the saddles are supposed to be a sintered (not a chromed) appearance and the mount screws must be offset and not dead centered like this.
  20. John C
    John C Friend of Leo's
    Kansas City
    But it did at one point have the walnut plug - you can see where it was pulled out as there is some residue in the truss rod opening.
