johnDH
I'm realizing now just how much aluminum in proximity to the air core coil affects it. I said something in a previous post about cramming the reactive load build into an aluminum enclosure like a Hammond 1402DV. I wouldn't try to do that.
I don't think we need to worry about an aluminium case. It has magnetic permeability virtually the same as air. Carbon steel is what not to use it has permeability about 100x greater.
https://en.m.wikipedia.org/wiki/Permeability_(electromagnetism)
I build my attenuators in an Al case. It's the ideal material for that reason and also for very good thermal conductivity to spread and dissipate heat.
I've checked this too by measuring inductance. No change i can measure when mounted on an Al plate. But put a steel bolt through the coil and it can add 50% to the measurements.
