Re-Wired my Board with Squareplugs
Discussion in 'The Stomp Box' started by knockeduptele, Nov 23, 2020.
  1. knockeduptele
    knockeduptele Tele-Holic
    London
    So having spent an enormous amount of time and effort (and cash) putting in isolated power supplies to my main board, the hums and buzzes were still there and it was all down to Jack casings touching each other creating loops, so a bit of tape was the practical solution, but since the pedals were all side access, I was looking for a better solution to allow tight spacing.
    Pancake plugs like swithcrafts are fine and robust, but every now and then you get to the point where you have to put in something cheap and nasty just to make it fit - below is the typical kind of problem
    So the complete board as it was (with the lid off) a complete rats nest after a couple of years of swapping things round and squeezing it in.
    So rewired wiht squareplugs and 5 mm Van Damme patching cable and a bit of a tidy up it became this (screened box at the back to allow for three inserts into the chains for things like Wahs and other boards - it does feed out to three primary amp chains (A B and Acoustic), it became this:
    Much neater (apart from the service loops) but with the lid back on its only me that knows, and there are only a couple of bits of tape in there in case anything moves
    One day I might get guilty and rebuild the top but I will doubtless change it all round again (as you do)
    And then back in the middle with its friends
    DeepDangler likes this.
  2. Edgar Allan Presley
    Edgar Allan Presley Friend of Leo's
    Colorado
    Did it solve the noise problem or just the spaghetti problem?
    I recently bought some flat patch cables from TourGear Designs. They're tiny and seem quite nice so far. It's too early to tell if they'll last.
