Rattle can TV yellow
Discussion in 'Finely Finished' started by Jim Sams, Apr 1, 2021.
  1. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    I am working on my second TV yellow finish and have a question...
    Is Mohawk Blond toner a path to success?
    Reran has is too banana yellow and Gracys sprays on horribly.
    Any better products?
    Mr Green Genes and nojazzhere like this.
  2. DjimiWrey
    DjimiWrey Tele-Holic
    austin
    i got some pretty nice results with reranch amber tint cuz i wanted lotsa grain reveal... if you don't want the grain reveal, perhaps play with some light colored undercoats before amber tinting ? i am by no means a finish maven tho, just for fun
    nojazzhere likes this.
  3. lowatter
    lowatter Tele-Holic
    SC
  4. lowatter
    lowatter Tele-Holic
    SC
    I've always thought reranch yellow was really popular for tv yellow.
    howardlo likes this.
  5. Despres
    Despres Tele-Afflicted
    Northeast again
    The pic below (if it shows up) is Mohawk Blonde toner in an attempt at TV yellow. It is over pine if you can't tell by the knot hole, so it wasn't going to be perfect, but I bet you could get a very convincing TV Yellow on mahogany if you did a white/pickling stain then applied a dark grain filler and followed with Mohawk Blonde.
    Mr Green Genes likes this.
  6. jfgesquire
    jfgesquire Friend of Leo's
    Lake View
    Blue Bill, zippofan and Telekarster like this.
  7. Wyatt
    Wyatt Tele-Afflicted
    Like Butterscotch Blonde, if TV Yellow is done the traditional way, the base is "white" and the yellow is put on with the clear. That's why all the pre-mixed TV Yellows are more '70s/'80s style.
    The original way... "Limed" finish from White/Milk White/Pickling White/White Wash/Mary Kaye/Blonde; then grain fill; then spray tinted clear.
    BTW, I'm currently spraying Gracey's Mary Kaye right now (still needs a another coat). I tested Mohawk White Wash toner but found it too bright. I always swap out the tips with ArtPrimo calligraphy tips and it has been spraying on really well (will add one more coat). The Art Primo fit Stewmac, Mohawk, Gracey's and (IIRC) Reranch.
    Mr Green Genes and urbandefault like this.
  8. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Thanks for the replies guys.
    I’ll try to warm up the graceys can and try it on a sample again. Otherwise I might give the whitewash a shot maybe topped with amber tint lacquer
  9. Wyatt
    Dan Erlewine goes into detail about this in the Stewmac finishing book (recommended!).
    The trend in the '50s was light color furniture, often made with lighter woods like ash, birch, etc. "Liming" was the process of making dark woods like mahogany and walnut look like lighter wood. They would white wash the wood to hide the natural color, then grain fill afterwards to bring back the "wood" appearance so that it didn't just look painted. This was a little before my time, but I'm old enough to remember these pieces around some households and used furniture shops.
  10. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Maybe I need to read that book.
    Tried the gracies again and it was awful. I’ll change the spray nozzle and try one last time.
  11. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Sorry the pic did not show up. Can you retry please?
  12. Despres
    Northeast again
    Trying to attach them rather than paste. With the two bodies sitting on the table, they are both knotty pine with Mohawk blonde sprayed on them - the one with more visible knots I stained the pine before putting the toner on, just to bring out the grain a bit. The one with less knots showing I did the same but sprayed some white shellac over the stain, sanding most of the way through the white until the grain showed, and then did the Toner - there is a bit more toner on that one. The light from my flash makes them look a bit more pale, so the second pic shows it in a different light. In real life it is not quite as pale as the first picture and not quite as yellow as the second. Blonde 1.jpg Blonde 2.jpg
  13. Mad Kiwi
    Mad Kiwi Friend of Leo's
    Land of the Long White Cloud
    Bloody hell that's a massive difference between photos!!
  14. old wrench
    old wrench Friend of Leo's
    corner of walk and don't walk
    Here is another shot of Mohawk Blond Toner -
    Colors can vary so much depending on things like the viewing monitor and the type off lighting used when taking the picture.
    The finish on the guitar above was about as simple as it gets.
    The sequence -
    Sanding sealer
    Neutral grain filler
    Sanding sealer
    Blond toner
    Finish coat
    The Mohawk blond toner is real nice to work with.
    The color is diluted enough to enable you to creep up on level of transparency or opacity that you want.
    You can get any effect you want, from just a hint of blond, all the way to a solid blond color.
    Despres, Wallaby and Mr Green Genes like this.
  15. Jim Sams
    Jim Sams Tele-Holic
    Charlotte NC
    Thanks. I should have the Mohawk today.
    I’m thinking whitewash, grainfill, blond toner, clear
    Mr Green Genes and old wrench like this.
  16. old wrench
    Do a test spray with the toner so you can gauge it's coverage, even if it's just on a piece of cardboard :)
    With light coats sprayed from the right distance, it's pretty easy to get a nice and even uniform coverage even if you are going for a lighter shade of blond.
  17. Mr Green Genes
    Mr Green Genes Tele-Afflicted
    MI
    Moe- Larry- Cheese! wub wub wub....
    Be careful of what you read on the internet, and I wouldn't be so quick to cite ReRanch as a resource (at least when it comes to TV yellow):
    Mm. If this were the case, they'd be using the finish on their high end instruments, the ones most likely to be featured on television. Instead, it was only offered on the Les Paul Jr, their inexpensive student-grade model.
    The Les Paul and Les Paul Custom were only available in gold, burst, or black. No "TV Yellow" (which was never called "TV Yellow", it was "limed Mahogany", which was only available on the Les Paul Jr TV Model).
    Les Paul preferred black guitars. They were supposedly fixing a problem that didn't exist. Les Pauls weren't even available in white until the 1970s.
    Lime green?!
    Enough. The "official" name for the color was "Limed Mahogany", which was a very popular blonde wood furniture finish in the 1950s. It was called limed mahogany because the wood was treated with calcium hydroxide, also known as lime. Lime is white, and has absolutely nothing to do with citrus fruits. Nothing.
    Limed Mahogany was the finish available on the LP JR TV model.
    Great. More with the fruit. Research? Reliable sources?!
    That must be it. They couldn't get the finish to work, but they decided to use it on their instruments anyway, rather than use any of the readily available finishes that do work. C'mon, guys. When you're in a hole, stop digging.
    Okay, enough.
    In the 1950s, Gibson came out with the Les Paul, an expensive, carved-top, bound solid body guitar, available in gold, burst, or black. They weren't selling very many.
    At the same time, Fender was selling lots and lots of Telecasters, which were relatively inexpensive unbound solid slab-bodied guitars, available in one color: blonde.
    In an attempt at capturing some of the market share that Fender was dominating, Gibson decided to come out with an inexpensive, unbound, solid slab bodied guitar that could compete with the telecaster.
    During development, it was referred to as the "Les Paul Jr, Telecaster Version". For obvious reasons, they couldn't market it as such, instead referring to it as the "Les Paul Jr, TV Model". Nothing to do with television sets.
    With that in mind, take another look at the Les Paul JR TV Model and see if the body and pickguard colors look familiar:
    See why doing a Telecaster in "TV Yellow" seems a bit perverse?
    Limed Mahogany was Gibson's imitation of Fender Blonde (now known as "vintage blonde").
    It's a semi-translucent white with a nitrocellulose lacquer topcoat. Just as with the Fender Blonde finish, the yellow comes from the lacquer topcoat ambering over time. If it's on ash or alder, it's Fender Blonde. If it's on mahogany, it's Limed Mahogany. Same finish, same color.
    The monkey chased the weasel.
    gerhard_k likes this.
  18. Mr Green Genes
    MI
    There you go. Post some pics along the way!
  19. Despres
    Northeast again
    After posting that, I tried taking about 10 different photos - it is like if I am closer than 4 feet it is really pale like the first one and further than that it shows up as safety yellow. I guess my photo skills aren't really that great, but I thought I could get at least one half-way between to show what it 'really' looks like.
    This is the best I can do - the one on the left is the one with some white shellac under it, the one on the right just blond toner over stained pine.
    Mad Kiwi likes this.
