Missing Link
Hey folks, this post is just to pass on a possible polyurethane finish that you may want to use in a pinch.
For starts I usually use a nice wipe on polyurethane finish (5-10 coats) or my compressor with a spray gun but my compressor is elsewhere and I am out of wipe on polly.
So went shopping for more wipe on polly and while checking out the products I came across a rattle can of polyurethane made by Varathane called Tripe Thick polyurethane saying three coats in one. This pecked my interest as most pollys in a spray can are thin and almost dry while being sprayed due to the thinning agents they use, like in Min Wax polly spray, hate that stuff.
Now some of you may be one up on me about this product but it is new to me so I am passing on the results from today's finishing project to maybe others that may want to give this a try for a finish.
First I am a lover of Ash wood and it's natural grain lines so most all my guitars I build now are Ash wood and with the grain to were you can feel it on the surface, that natural feel. I like the gran valleys to appear smooth when viewed and I always darken the grain before hand.
Well this Varathane spray just blew me away with just the one coat that I applied. I comes out of the can in a spray pattern almost as good as my spray gun so do not go slow or you risk runs. Practice as I did with some of the same wood type to get a feel of the spray and it pattern. The guitars body should be horizontal to work on for spraying in my opinion no matter how you apply your finish. This stuff is defiantly a self leveling finish (wet) so it needs to go on at a cans distance from the surface and at maybe 45 degree angle, and overlapping each side. Outside temp here today was 98 degrees and a humidity of 19%, perfect for shooting a finish. It is clear gloss but says nothing about the possibility of yellowing latter but that okay with me anyway if it does.
At first I believed I had fish eye in the finished after spraying but it leveled out nicely and diapered, smooth and glossy as it should be. The pictures really do not show how good it turned out but for me I would use this again over any other polly spray can product. One coat and it does look like at least two. I have the protection I wanted and a good looking surface with the grain lines.
Again just passing what I think on so for $10 if you can find in in your neck of the woods I recommend you at least test it out.
Comes in satin, and clear far as I no.
Was shot over 4 coats of Min Wax fake tung oil, lightly sanded with 2000 grit then one coat of Triple Thick.
