Digital Larry
A couple years back, I did a test to see which would win:
- Laney L5 Studio
- Headrush MX-5
- Mesa Boogie 5:25 Express with a Two Notes Captor-X and Line6 HXFX.
I still have the Headrush and the Laney. The Mesa didn't make it. Too complicated to deal with! This is what I'm learning after so many years. I get vastly more done with a limited setup.
Recently the MX-5 was going to get pressed into MIDI control, but it turns out that MIDI appears to be dead on this unit! I had not tested it before, and it's way out of warranty. So I tracked down the replacement board, which is about half the cost of a completely new unit. There's one ribbon cable I can't figure out how to reattach. I'm waiting for the guy to tell me how it's done. Otherwise the whole shooting match is worthless.
So in the meantime, I went and bought a TC G-Major 2 rack effects unit to go with the Laney. I also have a Nektar Pacer MIDI footswitch that has been sitting idle since I bought it a year or two ago. I got it set up so that one relay in the TC switches channels on the Laney, and the other relay does record/overdub via the footswitch input on a Boss RC-5 stereo looper. Did you know that the Boss RC-5 looper supports about 30 MIDI commands, but Record/Overdub is not among them? Many forehead slaps later! I actually have two presets on the Pacer, one which assigns the 6 main switches to block on/off on the G-Major, and the other one is for enhanced looper control. The Laney's FX loop goes to the TC, then stereo out to the looper. One side of the looper goes to the Laney's FX return while the other goes to an IR pedal. So I am combining the fixed (probably analog) speaker sim in the amp with the adjustable one in the pedal. It makes for some interesting stereo sounds.
Then this morning I thought I'd try out the Neural Amp Modeler plugin. I finally got that working but it's not an approach that works for me - having to have a ton of profiles to cover EQ and gain settings - argh. Audition much? Help! It sounded pretty good and latency wasn't upsetting.
I sat in front of the computer and played some riffs right into Ableton and it wasn't that bad. Generally I have steered clear of doing that, preferring to use a looper pedal, then transfer loops to the DAW. Maybe I'll try it and see if this would actually work for me. It would certainly remove a few steps compared to using a looper.
So then I went to Neural DSP and checked out some of their plugins. That is starting to look really interesting to me, to have just one or two amp choices and you dial them in to make them sound how you want them to sound. The Tone King one sounded great. I'm not really into super high gain, though I'd probably like another one that is a bit further up the gain mountain.
The end (for now)
DL
- Laney L5 Studio
- Headrush MX-5
The end (for now)
DL
