Radius block vs. bar for fret level.
Discussion in 'Tele-Technical' started by backporchmusic, Apr 15, 2018.
  1. backporchmusic
    backporchmusic Friend of Leo's
    Is a radius block more or less effective at fret leveling than a traditional bar?
    Is it more or less problematic?
    And yes, I know people who ave been doing this for years will have lots of ideas--but I'm just getting started, so keep that in mind. o_O
  2. moosie
    Western Connecticut
    I've only been at it for a couple years. I prefer the bar. Stay generally in line with each string, and radius doesn't matter. Compound is as easy as 9.5, 12, 7.25. Just need the one tool.
    I find that even careful pressure on a radius block wears more on the edges than the center.
    If you think about what a string sees, there is no radius, just one fret top after another.
    backporchmusic likes this.
  3. 5ofeight
    5ofeight Tele-Holic
    Glasgow
    It wont matter much what you use as long as you start out with a flat neck, Though in saying that I did watch a video (somewhere of someone) who used a truss rod and 3 brass nuts. I'll have a quick google around and see if I can find the youtube video agaion.
  4. backporchmusic
    I wasn't sure if the radius blocks were for shaping an unfretted board, or perhaps a first pass once new frets have been installed.
    I didn't know if people were actually using them as leveling tools until I looked at the recent sandpaper/leveling thread. Trying to get a feeling for what people do with them. I think the point about 'think about what a string sees' is very valid.
  5. 5ofeight
    5ofeight Tele-Holic
    Glasgow
    I am sure this is the one, bit on the long side but Sams Youtubes are normally very informative indeed.
  6. highwaycat
    highwaycat Tele-Meister
    California
    I recommend learning the basics like Ron's tutorial, then later on you can decide if you want to try different techniques and tools. I only use radius blocks during a refret.
  7. HolyTele Tube
    HolyTele Tube TDPRI Member
    Prosperity, Sc
    I prefer the radius blocks but they get spendy so I only have 12”. My back up is a old hand plane. I have used it with excellent results. I got the idea from frets.com.
  8. moosie
    Western Connecticut
    On a refret, I'll use the blocks on the unfinished neck, but not the frets.
  9. TimTam
    TimTam Tele-Holic
    Melbourne
    Dave uses a radius block for levelling (sometimes, and other times a beam) ...
  10. KokoTele
    KokoTele Doctor of Teleocity Vendor Member
    albany, ny [not chicago]
    The problem with using a short block is that it will tilt forwards and backwards as it rides over high frets, so you wind up sanding unevenly and have to do something else to compensate for it. It's also difficult to sand evenly along a whole neck.
    I'm not saying it's the wrong tool, just that there are considerations you have to be aware of.
    If I'm working on a neck with deep divots in the frets, I'll use a radius block to sand them out quickly to get them into rough shape, then use a beam to true them up.
  11. guitarbuilder
    I would want a machined bar or some dead flat surface to level frets. Float Glass, Granite, machined steel. I have a couple different long extruded radius blocks, and they do a great job of radiusing fretboards, but I wouldn't use them to level frets after installation. For one thing, the radius of the top of the frets will be different than the beam radius.
  12. TimTam
    TimTam Tele-Holic
    Melbourne
    Ben Crowe (Crimson Guitars) says 'no' to radius blocks for fret levelling (at 6 mins in) ...
  13. GFrank
    GFrank Tele-Meister
    Brooklyn, NY
    I think either one can work effectively, although I prefer a flat bar by a good amount.
    The key to leveling, for me, is to use a sharpie and draw a thick black line down the top/middle of each fret, that way you can see exactly where and how much you are sanding down the frets by where the ink is removed.
  14. backporchmusic
    Thanks for all the great answers and info.
  15. moosie
    Western Connecticut
    I agree with what the Crimon Guitars guy says. Just in fewer words. :)
    What he said about just taking a small portion of the fret top, because the 1" bar doesn't follow the radius, that's what I meant by "think about what a string sees".
  16. TimTam
    TimTam Tele-Holic
    Melbourne
    He is a tad verbose, but positively succinct in comparison to his fellow countryman Sam Deeks, who recently posted an 8 hour youtube guitar vid ! ;)
