Quilter versus Tech 21 Blonde
Discussion in 'Amp Central Station' started by Charlie Bernstein, Mar 7, 2021.
  1. Charlie Bernstein
    Augusta, Maine
    Hey!
    I have a Quilter Microblock 45 mini-amp and a Tech 21 Blonde stompbox.
    The Quilter is for plugging into a 210 cabinet, and the Blonde is for plugging into PAs.
    My questions:
    - Can the Quilter run straight into a PA?
    - Can the Blonde run straight into the 210 cab?
    If they can, I might get rid of one.
    Thanks!
  2. The Angle
    The Angle Tele-Holic
    Seattle, WA
    The Tech 21 can't power a speaker cabinet. It's essentially a preamp, so it needs to be coupled with a power amp before driving speakers at any sort of volume.
    I've never used the Quilter you mention, but it is a power amp, right? So you should be able to run the Tech 21 into the Quilter and then into a 2x10 cab.
    Tim S, PhredE, ale.istotle and 3 others like this.
  3. Charlie Bernstein
    Augusta, Maine
    Thanks!
    And what about the Quilter? What happens if I plug it into a PA? Kaboom?
  4. The Angle
    Seattle, WA
    I just looked up the Quilter's manual online. I quote: "The OUTPUT JACK MARKED SPEAKER must be connected ONLY to a separate 4-16 ohm speaker. Do not connect to electronic inputs. The HEADPHONE OUTPUT may be used to feed other electronic inputs or standard headphones."
  5. W.L.Weller
    W.L.Weller Tele-Holic
    Queens
    I'm almost positive that the Quilter Micro 45 is...right.
    I think the Quilter Interblock 45 can be used instead of your Tech21 directly into a PA. Meaning, it has cabinet emulation and a balanced line out.
  6. cousinpaul
    cousinpaul Friend of Leo's
    Nashville TN
    The OP has a MicroBlock 45; not the InterBlock 45.
    Charlie Bernstein likes this.
  7. ale.istotle
    ale.istotle Tele-Holic Silver Supporter
    Pennsylvania
    From the manual. You cannot connect the speaker out to an electronic input - it has to go to a speaker. It's just too powerful for a mixer or pa input.
    You can connect the headphone out to a mixer or panel.
    What I'm not clear on is whether you MUST connect the speaker out to a speaker to use the amp or if you can use it only as a preamp.
  8. PCollen
    PCollen Friend of Leo's
    Man of the World
    So, the OP could buy, for instance, and ALTO FRFR powered speaker, and get rid of the Quilter and the 2x10 cab.
  9. Tuneup
    Tuneup Tele-Holic
    The Interblock can,. the Microblock can not run direct to PA.
  10. W.L.Weller
    Queens
    No, the Microblock (and all solid state amps I have read about) do NOT NEED to be connected to a speaker to prevent damage to the amplifier.
    This is confusing, because vacuum tube power amplifiers ALWAYS NEED a reactive (speaker) load connected to their outputs to prevent damage to the amplifier. [This doesn't mean you can plug the speaker output into PA or other inputs expecting an instrument or line level.]
    If you like the sound out of the Microblock 45 headphone output plugged into the PA, you don't ever need to plug it into a speaker cabinet.
  11. Charlie Bernstein
    Augusta, Maine
    Now I know everything. Thanks!
  12. Charlie Bernstein
    Augusta, Maine
    Re 3: I wonder why anyone would hook it up to earmuffs or an abucus.
    =O.
    ale.istotle likes this.
  13. Charlie Bernstein
    Augusta, Maine
    Now there's an idea! I'll try it sometime and hear how it sounds.
