Quick wiring question
Discussion in 'Shock Brother's DIY Amps' started by Lavochkin, Sep 10, 2019.
  1. Lavochkin
    Lavochkin TDPRI Member
    Ithaca, NY
    About to order parts for a first build (Micro Champ). About wire, which is prefered, solid or stranded?
    TIA
  2. Phrygian77
    Phrygian77 Tele-Afflicted
    Crawfordville, FL
    Solid is less microphonic. Highy recomend it.
    sds1 and Lavochkin like this.
  3. sds1
    sds1 Tele-Afflicted
    Orlando, FL, USA
    Prepare for 18 different answers. Seems to be a matter of primarily personal preference.
    I've settled on 22ga stranded topcoat wire myself.
    Nickfl and King Fan like this.
  4. kbold
    Not too thin, not too thick: just right.
    I also like using cloth covered wire (as used in vintage guitars). It's tinned 2 strand, push back the cloth to solder (no need to strip the insulation), and the finished product looks really good.
    Kevin Wolfe and sds1 like this.
  5. dan40
    dan40 Tele-Afflicted
    Richmond Va
    Hoffman sells some very nice solid core if you choose to go that route. Valvestorm sells a 22awg, pre-tinned topcoat stranded wire that holds it shape very well and doesn't melt as quick as others when soldering. It has become my favorite wire unless I want to stay period correct with the cloth covered.
    King Fan likes this.
  6. Phrygian77
    Crawfordville, FL
    That stuff is stranded and pre-tinned. Which makes it more stable, like solid core.
  7. Phrygian77
    Crawfordville, FL
    Bottom line, pre-tinned wire.
    dan40 likes this.
  8. Phrygian77
    Crawfordville, FL
    Yes, solid core cloth wire is pre-tinned also.
  9. tubedood
    tubedood Tele-Meister
    Orlando
    I like the solid core (I got mine from the Hoffman site). Some folks say solid core is prone to breaking but I never have had an issue with that yet. I guess just don't keep bending it...
    The topcoat I hear is great also, I just haven't tried it yet.
    King Fan and Phrygian77 like this.
  10. Phrygian77
    Crawfordville, FL
    Solid core can break, if you keep bending on it like a retard. Like any other solid wire.
  11. ArcticWhite
    ArcticWhite Tele-Holic
    Portland Oregon
    If you grab a free organ or two off Craigslist, you will have all the vintage wire you will ever need.
    Shielded, solid, and some cloth wrapped.
    Also Speakers, Transformers, Tube sockets, resistors, caps, and tubes.
    I hardly buy anything at all.
    RollingBender likes this.
