Quick question
Discussion in 'Shock Brother's DIY Amps' started by Bitsleftover, Oct 8, 2019.
  1. Bitsleftover
    Bitsleftover Tele-Meister
    Lincolnshire UK
    Can a bad coupling cap cause a high pitch squeal at higher gain?
    Thanks
    Mick
  2. corliss1
    Lansing, MI
    Yes? No? Maybe? A bad coupling cap would be leaking DC into some area it shouldn't. What that would cause in the particular circuit you're working with is hard to say. Usually the result is static on a pot since there is DC as you turn the control.
    King Fan likes this.
  3. Bitsleftover
    Lincolnshire UK
    Thank you.
  4. muchxs
    muchxs Doctor of Teleocity
    New England
    High pitched squeal is usually a microphonic 12AX7.
    Turn the amp down. Tap the tubes.
    King Fan and Wally like this.
  5. Wally
    Or microphonic pickups...or being too close to the amp?
  6. Bitsleftover
    Lincolnshire UK
    Tried swapping all tubes out. Nil fix.
    I chopsticked around and thought I’d solved it. But it came back just as mysteriously as it started.
    I’m working away this week so I’ve had to walk away from it. Which is good, because I was pulling my hair out.
    A fresh set of eyes next week I think.
    Thanks for your help.
  7. Bitsleftover
    Lincolnshire UK
    Bizarrely, it only happens on the bridge pickups of a few guitars. One Tex Special Strat and a potted humbucker les Paul. Both of which behave through other amps.
    Thank you for the reply
  8. muchxs
    New England
    High pitched squeal is always a possibility in high gain amps. there are certain high gain designs that are never built as combos for that reason. You want to keep the speaker away from the tubes.
    Some combinations are just over the top. They're going to whistle like a litter of hungry piglets. A good recipe for whistle is to stick a pedal in front of a high gain amp. For example a JCM800 with an old Distortion + in front of it will whistle.
    Listen to the guitar part around 2:25. It's trying to whistle. I'll bet they cleaned the guitar track where they could.
  9. Bitsleftover
    Lincolnshire UK
    Hahaha! Love that one!
    I’ve turned a Marshall class 5 into a 1959slp preamp feeding the class 5 single ended power amp.
    Only having room for one input jack, I hard wired both normal and bright channels in parallel.
    The normal channel is fine from zero to 10.
    The bright channel is sometimes ok from 0-10 but sometimes whistles at around 9.
    With normal on around 7 and bright around the same (unfortunately the start of the sweet spot) the whistling starts and gets worse up to 10.
    I can change the pitch of the whistle by chopsticking around the v2a cathode (.68 bypassed) jumper wire. But I can’t get it to go away. Or certainly not stay to away.
    Because it is a mutilation of a totally different pcb, the layout is less than ideal and there’s not much to be seen nor can be traced from above.
    The PCB is very fragile and I burned a few traces trialing different values caps and resistors so there are a few “compromises” in quality of work which Id rather stab my self in the eyeball with my soldering iron than share with you guys!
    But the main one is that the V2b .68 bypass cap is connected and grounded right next to the wires that go to the tube. The ones that change the pitch of the whistle.
    I think I’ve answered my own question and I think this story will end with me replacing the pcb with a freshly laid out turret board which is what I should have done from the start. At least I’ve done all my tweaking now and have proven the concept.
  10. muchxs
    New England
    Ah, so!
    Here's what you need to do:
    Change that bypass cap. You may be able to get rid of your oscillation with a 1uf in there. Or 2uf.
    I suppose you're bypassing a 2.7k resistor. As you go up with the cap, go down with the resistor. You can change just the cap if it does the trick. If you want to go belt and suspenders go 1.8k- 2.2k bypassed with a 2uf (or so) cap.
    You can also use a small value cap across the plate resistor for a snubber. A .005uf will almost certainly kill your oscillation. You could start at .005 and go smaller until the piglets come back.
    Yup. That'll do it.
    Bitsleftover and Wally like this.
  11. printer2
    I had an amp squeal at maximum gain, turned out to be capacitance around the input jack, don't remember more than that. You might try temporally shielding parts/wires to try and pin it down. Of course insulate where in danger of contacting live voltages.
    Bitsleftover likes this.
  12. muchxs
    New England
    Bah! Chokes 'n' snubbers' Snubbers 'n' chokes.
    :D :D :D
    I just tore down some sort of old UHF junk. Chokes 'n' snubbers everywhere.
    :cool:
  13. Bitsleftover
    Lincolnshire UK
    Thank you so much for your help! I really appreciate it.
    Something thing just occurred to me when you mentioned a cap across the plate resistor.
    I changed the signal flow through the amp to move the tone stack to after a cathode follower.
    In doing so I’ve changed the flow from
    V1a-V1b-V2a-V2b
    To
    V1a normal\
    V2b-V2A
    V2a bright/
    Which means V1a is picking up its B+ from the right spot. But My bright channel input stage (V2a is picking up its B+ from the wrong side of 10dropping resistor.
    Likewise my next gain stage is picking its B+ up from the same point as my normal channel 1st stage.
    I can rectify that easily when I get home if that would make a difference?
    I’ll edit a schematic later tonight to illustrate invade my rambling isn’t very clear.
  14. muchxs
    New England
    Yeah. Sort that out.
    :cool:
  15. Bitsleftover
    Lincolnshire UK
    This is the current state of play.[​IMG]
    Sent from my iPad using Tapatalk
  16. Bitsleftover
    Lincolnshire UK
    Well...
    I corrected the node issue. Nil fix
    Increased the V1B Bypass cap to 2.2 uf - Nil fix.
    Reduced the bright channel cathode resistor to 2k2 - Nil fix but slight improvement.
    Then to 1k8 - About the same.
    0.0047 cap across V1B plate resistor - Slight improvement.
    Now only squeals when one channel on 10 and the other on 9.
    Tried a cap across the normal channel plate resistor.....No sound!?!?!???!?
    Prodded and poked around and the only way I could get any reaction from amp was by tapping the pcb near the normal channel plate resistor and cap which make a loud pop.
    Removed the cap. Powered up. Sound back- No squealing at all!
    Tried the .68 cap back on the bright channel cathode.... Perfect.
    This thing is making a monkey of me.
    If the squealing comes back next time I play it, it’s getting tossed over my balcony and can spend the rest of its days at the bottom of the Trent river!
    I think I need a new hobby!
    I suppose I could try and actually coax a tune out of my guitar?
    Thanks for all your help. I’m sure I’ll be asking for more advice when I get over my strop and if inevitably strats squealing again.
    Have a great weekend all.
  17. Bitsleftover
    Lincolnshire UK
    Well...No more squealing piglets. But having had time to put it through it’s paces, I think it’s time to concede that this mission has failed.
    While the tone is great, up to a point...It runs out of gain just as things are starting to get interesting.
    My amp on 10 is about what I would expect on 5. Ie crunchy with a Les Paul, just starting to break up a bit on the Strat and tele.
    I can get there by adding a Timmy or EP boost up front. But that wasn’t the object of the exercise.
    The pcb is mutilated beyond all recognition and there are mods soldered on top of mods and bodges on top of bodges.
    On a plus note, I’ve established I love having bright and normal channels in parallel. And splitting the cathodes was a great success getting me closer to where I was aiming.
    But I think the time has come to admit defeat, salvage anything worth keeping and take a serious look at Robrobs Bassman/JTM LTP Micro.
    Thanks for all the help.
    I’m calling it!
    Time of death 1601.
    Switch off the machines
