quick question will this nut file work for gauge 10's?
Discussion in 'Other T-Types and Partscasters' started by ben smith, Oct 9, 2019.
  1. ben smith
    ben smith Tele-Afflicted
    london
    I bought this because it's cheap but will the thinnest 0.4mm be small enough for the high string on gauge 10's? i'm not spending £80 on proper files just for one guitar! I can build stuff but math is not my strong point haha. thanks a lot s-l1600 (1).jpg
  2. moosie
    Western Connecticut
    So-called '10 gauge' is simply .010", or ten-thousandths of an inch. Google does the rest.
    Short answer: 0.04mm is .016". So, no, not really. It'll work for the G string, though! ;)
    EDIT: assuming those 'work' at all for cutting nut slots. Sometimes ya just need the tool for the job...
    Try a set of Hosco.
    Chunkocaster and ben smith like this.
  3. ben smith
    london
    bugger! thanks
  4. moosie
    Western Connecticut
    See my edit for the best files, IMO, and not $80, either.
    ben smith likes this.
  5. moosie
    Western Connecticut
    If you can't justify it for one guitar.....
    Get more guitars!
    You knew that was coming, I bet...
    jimilee and ben smith like this.
  6. ben smith
    london
    does anyone know where to find the right sizes i need but on a budget?
  7. ben smith
    london
  8. ben smith
    london
    oh wait life saver! thanks man they look good! thin enough then? i'm freakin out
  9. ben smith
    london
    but from the states in would take too long, can you find anything in the uk? i just can't think right now! how about the ones i gave you a link for? ill owe you one
  10. moosie
    Western Connecticut
    Your link is not actually nut files. More like general purpose, not sure what...
    I figured you didn't want the ones I posted here in the US, but the brand may well be available over your way. They're Asian import. And they're the right thing. I use them all the time. They don't look thin enough, but they are. And they don't bind as readily as the thin ones that look like hacksaw blades.
  11. moosie
    Western Connecticut
    I think you'll have better luck than me. Servers sense location and tailor results....
  12. ben smith
    london
    thanks buddy i sorted it!
  13. hopdybob
    hopdybob Tele-Afflicted
    netherlands
    dremeld feeler gauge will do the trick to.
    buy a metal feeler gauge set with the right thicknis blades an with a dremel cutter ore triangle metal file cut teeth in the blades while clampt the whole bunch in a clamp.
    getting to start with a fine jigsaw blade will help.
    with those nozzle cleaners you can round the bottom a bit, but really cutting a slot? no way, i tried that
  14. KelvinS1965
    KelvinS1965 Tele-Holic
    Wokingham England
    I got my set from Axecaster when they were slightly reduced from the current price. They worked really well and even though I only bought them for one guitar, I knew I'd end up using them on others too. They greatly improved the tuning stability on my Gretsch and I ended up fitting a bone nut to my Les Paul, so they've paid for themselves now really.
    https://www.axecaster.co.uk/index.php?main_page=product_info&cPath=42&products_id=302
    Don't take long to come either.
  15. hopdybob
    netherlands
    i have the chinese cheap version, and if one thing is not right its the V schape,
    then i would be better to buy only the G/B/E files an a cheap set of these ones
  16. Chunkocaster
    In space with Ziggy
    The cheapest set of those Hosco files on ebay for Australia is $125 bucks plus 10%.:mad:
    7 years ago they would have cost $54 bucks the same as in that link.
  17. beagle
    beagle Friend of Leo's
    Yorkshire
    X-Acto razor saw extra fine blade for E and B, the tip cleaners will do the rest. I've never owned a "nut file" in my life. £80 my arse. Some people just like to throw money at things.
  18. Chunkocaster
    In space with Ziggy
    You can just use cut down lengths of wound strings.
  19. ben smith
    london
    thanks buddy!
  20. ben smith
    london
    that outfit gets me every time! haha
    Chunkocaster likes this.
