Quick question about adding a 4 way switch
Discussion in 'Squier Tele Forum' started by wewwllad, Sep 14, 2020.
  1. wewwllad
    wewwllad TDPRI Member
    Massachusetts
    Hey all, I have a Squier Bullet Tele that I'll be adding an Obsidian Wire 4 way kit to (as well as swapping the control plate for a Fender one to fit the pots, new bridge from GFS to stop setup/intonation and buzzing issues, solid-shaft knobs etc) and I'm planning on swapping the pickups at the same time.
    I've heard that to put Tele pickups in series with a 4 way switch, you have to independently ground the neck pickup cover by cutting the jumper from the cover connection to the negative lead connection, and adding a new wire that gets grounded somewhere else such as on a pot (in my case the Obsidian Wire kit has some extra grounds)
    However, looking at this set of pickups at Sweetwater (https://www.sweetwater.com/store/de...an-stl-1b-vintage-broadcaster-tele-pickup-set) I've noticed that the bridge pickup also has a jumper connecting to the baseplate that I am assuming is a grounding connection as well. Do I need to also cut the jumper and reground this baseplate?
    This may be a newbie question and it may be better suited for another subforum than the Squier one, but I figured the folks here might be equally or more knowledgeable about modding Squiers. Cheers
  2. Iago
    Iago Friend of Leo's
    Brazil
    If you do it to the neck pickup you don't do it to the bridge. It's either one ir the other, but not both.
    wewwllad, Peegoo and gregulator450 like this.
  3. gregulator450
    gregulator450 Tele-Afflicted
    The Dry Side
    wewwllad likes this.
  4. tah1962
    tah1962 Friend of Leo's
    Heart of Illinois
    Welcome to TDPRI. :)
  5. wewwllad
    Massachusetts
    Ohh okay, thank you!
    Thanks for the welcome :)
    tah1962 likes this.
  6. gregulator450
    The Dry Side
    And, welcome to TDPRI!
  7. iandope
    iandope TDPRI Member
    Malaysia
    have fun modding!
