Questions about adding a tube rectifier transformer
Discussion in 'Amp Tech Center' started by Dan_Pomykalski, May 20, 2020.
  1. Dan_Pomykalski
    Dan_Pomykalski TDPRI Member
    Madison, WI
    I need to add a filament transformer to my Champion 600 to get the tube rectifier to work, but I have a couple of questions I'm hoping someone can answer.
    I'm assuming I would solder the primary wires to the power switch?
    Would I need to add another fuse? Or could I use the fuse holder I already have? If I used the same fuse holder would I need to increase the fuse?
    I wasn't quite sure what to search for, so sorry if this has already been covered. I tried google, but I didn't see any schematics for adding a transformer.
  2. corliss1
    Lansing, MI
    The primary side would be 120V, so you'd wire that to the same switch as the main power of the amp. You'll be using the same main fuse.
    I'd probably bump the fuse by 500mA to handle some of the extra inrush current that'll happen when you first switch it on, I'm guessing that'll be enough.
  3. Dan_Pomykalski
    Madison, WI
    Perfect! Thanks!
  4. Dan_Pomykalski
    Madison, WI
    Would a dim-bulb tester let me know if the fuse wasn't big enough?
    Edit: Also, thank you for not replying with “why are you doing this” and the “tube amps have lethal voltage” lecture.
  5. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    prolly not since that would be the current limiter
  6. corliss1
    Lansing, MI
    So you blow a fuse? If so, put in the next size up :D That's a pretty cheap science experiment.
    Might be a good idea to start with the light bulb limiter to make sure you don't have a miswire somewhere though, or else putting in a larger fuse could cause problems.
    King Fan likes this.
  7. dan40
    dan40 Tele-Afflicted
    Richmond Va
    If your amps' original power transformer has a bad filament winding preventing your rectifier tube from working, Weber sells a "copper cap" rectifier plug in that works without the 5v filament winding. You simply plug it into the rectifier socket and it will deliver the same voltage that the original rectifier tube provided.
    https://www.tedweber.com/wy3gt
  8. corliss1
    Lansing, MI
    @dan40 - he's talking about the reissue, which didn't have a rectifier tube/socket/5v wiring from the factory.
    Dan_Pomykalski and dan40 like this.
  9. Jon Snell
    Jon Snell Tele-Meister
    Jurassic Coast. UK.
    Fitting a valve rectifier will reduce the available HT by about 60volts, depending on the chosen valve. That may give you less power before it breaks up.
  10. Lowerleftcoast
    Lowerleftcoast Tele-Holic
    california
    My silverface deluxe reverb suggests a 1 amp slo blow fuse. The smaller 5E3 deluxe suggests a 2 amp slo blow fuse.
    I bet your champ can live with 1 amp to 2 amp without problems.
