Question, single channel AA964 build
Discussion in 'Amp Tech Center' started by Diverted, Oct 11, 2019.
  1. Diverted
    Diverted Tele-Meister
    Bristol RI
    Hi all, a few quick questions about building a Vibrolux Reverb AA964, single channel (see pic).
    Question 1: I assume I should remove the 220K isolation resistor circled in blue? The mixing resistor on the unused normal channel is shown removed in the red circle.
    Question 2: Looks like two cathodes in the normal and tremolo channel are shared (green circles) . Assuming I should change the cathode resistor to 1.5K (original at 820) to account for it not being shared by two cathodes?
    Question 3: Anything else I should do as I pull the normal channel out?
    Thanks!
    Ted
  2. peteb
    peteb Friend of Leo's
    Cascadia
    Per Robrob and his blackvibe amp, you will want both the isolating and mixing resistances in place otherwise the signal going into the LTPI is too large.
    Diverted likes this.
  3. schmee
    schmee Poster Extraordinaire
    The resistor across the first preamp cathode cap that is 820 should be changed to 1500. Shown here off p in 8 of the first 7025
  4. Diverted
    Bristol RI
    Check on the 1.5k cathode resistor. Thank you!
    And Peteb, thanks for the Blackverb tip. I hadn’t seen that before and it’s a big help. I’m using both reverb and tremolo and deleting the normal channel so I take it I would just put one 220k out of the second gain stage into the PI? Thank you!
  5. schmee
    Yes , I believe so.
