Question re. humbuckered Tele's
Discussion in 'Telecaster Discussion Forum' started by SixStringSlinger, May 23, 2020.
  1. SixStringSlinger
    SixStringSlinger Friend of Leo's
    Space
    I've been curious about putting a humbucker in my Tele's neck position (it's an MIM Standard already routed for it). Really just kicking the idea around at this point, but I'm curious about something: What would the middle position sound like in this configuration (assuming a typical single-coil Tele bridge pickup)? I really like the middle position with two single coils for some country stuff and other things. How would the same position compare with a humbucker in the neck? Examples welcome.
  2. jfgesquire
    jfgesquire Tele-Afflicted
    Lake View
    A LOT fuller. Flipping the switch to the middle is like just lowering the EQ a little on the low and mid, and up a little on the high. Not anything like a standard SS Tele to my ear.
    I think a standard Tele SS has that twang because the pickups are better balanced and spaced so that they are naturally a little out of phase with each other.
    Why not change one of the pots to push/pull and coil split the humbucker while you're under the hood?
    Sent from my LG-H932 using Tapatalk
  3. Thinline casket
    Thinline casket Tele-Meister
    Flintstone
    I have a thinline with 2 HBs and a thinline with 2 WRHBs. So I can't answer your question directly. However, telenator raves about the middle position of a custom with a WRHB in the neck. It's worth considering. I had a late 70s custom in the middle 80s. I don't remember what it sounded like, but I remember loving it and regretted selling it.
    rockymtnguitar likes this.
  4. puddin
    puddin Tele-Afflicted
    Punta Gorda, florida
    mini humbuckers sound sweet. cheers..
    rockymtnguitar and Axegrinder77 like this.
  5. Verne Bunsen
    Verne Bunsen Tele-Afflicted
    Sonoran Desert
    I have a 90’s Tele Special with Lollar Special T in the bridge and El Rayo humbucker in the neck. Together they sound like this:
  6. rockymtnguitar
    rockymtnguitar Tele-Holic Silver Supporter
    Colorado Springs, CO
    It's a different animal, but I have a G&L Bluesboy Tribute with a humbucker in the neck and a MFD bridge pickup, and the middle position is totally the sweet spot on that guitar. It's a different sound then either pickup individually and I really like it. Again, different components then you're considering, but I guess this is my way of saying that you might really enjoy the configuration.
  7. hemingway
    London, UK
    I find it's less interesting than the normal tele middle position when clean, but when you add some gain it becomes a really useful sound.
  8. brookdalebill
    Austin, Tx
    I’m a long time proponent of putting a humbucker in the neck position of my Teles.
    All three of mine have humbuckers.
    My all time favorite is the TV Jones Supertron.
    I also like Duncan Stag Mag, Jazz, Seth Lover, and various Antiquity series humbuckers.
    The middle position is much more useful with a neck humbucker.
    It’s my “go to” strumming/rhythm sound.
    Love it!
    39martind18, rockymtnguitar and mimmo like this.
  9. jvin248
    jvin248 Doctor of Teleocity
    Lions & Tigers oh Mi !
    The other Humbucker option .... get a $12 4-way switch to install in your SS Tele so you can put both coils in series for a humbucker tone.
    Any Tele I get that I plan to play (vs flip) gets a 4-way switch and a reversed control plate (V-T-Switch to the rear).
    If you go the full humbucker neck pickup plan, you could use a push/pull tone pot to split the neck coil out for single tones.
    Or use a 5-way Strat switch for what are essentially three single coils with push/pull to put the humbucker in series mode.
    richiek65 and rockymtnguitar like this.
  10. rockymtnguitar
    The four way switch makes all the difference in the world. I agree with @jvin248 - all my "traditional" teles get it. There sure is something sweet about that Humbucker/MFD combo I mentioned above, however.
  11. richiek65
    richiek65 Friend of Leo's
    Sydney NSW Australia
    Yup, just hot rodded my Squier, mid position sounds juicy IMG_20200523_082434.jpg
    puddin, mimmo, Macrogats and 3 others like this.
  12. 39martind18
    39martind18 Friend of Leo's
    Spring TX
    I'm with richiek65, I put a mini hum in my partscaster, and love the sound. I added another wrinkle, installing a Jazz bass control set, with individual volume controls for neck and bridge, giving an infinite tonal palette to the mid position. _633.JPG
  13. LutherBurger
    LutherBurger Poster Extraordinaire
    NYC
    I have one HS Tele with an old MIM alnico 5 pickup at the neck and a ceramic humbucker wound to around 8-9k at the bridge. The middle position sounds schweet.
  14. dougstrum
    dougstrum Friend of Leo's
    blu ridge mtn cabin
    Neck humbucker is a classic mod for a Tele. I feel like it adds versatility and the middle still has that two pickups in parallel sound. I have tried all different types of neck humbuckers. My favorite is DiMarzio fast track1, this one is paired with DiMarzio pre b-1. IMG_20191025_160848740_HDR.jpg
    39martind18 and BBQedIguana like this.
  15. elelpe
    elelpe Tele-Afflicted
    SEA
    I had Nocaster bridge and Duncan '59 neck. The middle position sounded fantastic. There was slightly unbalanced output between two pickups. When I replaced Nocaster with hotter pickup, the middle position sounded less interesting.
  16. moosie
    Western Connecticut
    I can only tolerate middle position by doing 'something' to the humbucker. Either splitting it, or wiring it with parallel coils. Full series humbucker simply does not play well with singles. IMO, of course.
  17. yyr123
    yyr123 TDPRI Member
    Austin TX
    Well I put a P90 in there and it gave me the sustain and the gain I was looking for....but I went with a 4 position wiring which to me makes the difference
    However I am in love with the clean quack of the 4th position of a Strat
    Soooo
    I went back to my single coil in the neck and a Seymour Duncan Qtr Pounder in the bridge and the 4 way still, so I get the clean strat quack but I ran my PU’s wired in....this config
    - in phase
    - in phase series (neck / bridge)
    - out of phase
    - out of phase series (neck / bridge)
    I mainly use out of phase and for gain the in phase series - which is basically a humbucker sound with the brightness of the bridge
    A series wired bridge and neck is basically a humbucker type of resistance/ the p90 was nice but this way I get the classic tele look....
    G&L ASAT Classic - USA Model !!!
  18. yyr123
    yyr123 TDPRI Member
    Austin TX
    BBQedIguana likes this.
