Question: Bender players
Discussion in 'B-Bender Forum' started by T Prior, Jul 5, 2020.
  1. T Prior
    T Prior Poster Extraordinaire
    Charlotte NC
    G or B, doesn't matter. Curious .
    When you play out or practice, do you play other guitars or now JUST the Bender ?
    For the past 3 or more years I have played nothing but B Bender guitars , for the last year the same one, every gig, every practice session, whatever. Its the guitar I pick up all the time.
    My other guitars are sad , very sad, especially my 89 /52RI which has been my best friend for over 15 years !
    So...
    That Cal Webway likes this.
  2. Rick Towne
    Rick Towne Tele-Afflicted
    Woodland Hills, CA
    I have a 12 string which I usually take with me, but my two G&L strat style guitars; Legacy and S-500, get played maybe once a year since 1997. And so it’s the early ‘90’s ASAT Classic benders, one a Glaser b/g (90%) or the other, a Parsons b (10%) that are played every time everywhere. It helps that both have strat middle-neck pickups and 5-ways.
  3. ChrisLarcombe
    ChrisLarcombe TDPRI Member
    Midlands, UK
    I have three 'working' guitars; a strat, my beloved tele, and an acoustic. I hardly pick up the strat now, and only do so if I'm doing pop-orientated stuff that requires it, or funk for example. Even then, I enjoy sneaking the bender work into those fields, seeing how much i can get away with it before people ask me to put a lock on it. Obviously I don't go overboard, but you'd be surprised how just the movement from one note to the next through a bend instead of two plucks grinds some people's gears. Anyway, to answer your question, not much at all!
  4. ReverendRevolver
    ReverendRevolver Tele-Afflicted
    Ohio (Nerk)
    I've been looking for an '89 tele, if you aren't using it anymore.....
    I've been impressed by benders since I saw a VHS of a guy playing one when I was 11.
    From what you're saying, I need to steer clear, or my other electrics will collect dust.
  5. PlainAllman
    PlainAllman Tele-Afflicted
    Van Zandt Co, Texas
    The more I read about benders the more I become convinced I want one.
    scook and brookdalebill like this.
  6. brookdalebill
    Austin, Tx
    I use one of my B bender guitars, usually my avatar guitar on all my “all country, all night” gigs.
    I’m using it as we speak (sorta-I’m on break).
    I don’t have, want or need a G bender.
    The trio gig I’m doing is a 50/50 rock/country gig.
    I used the avatar guitar for the first set.
    I’m going to use my PRS Singlecut for the last set.
    I feel sorta “naked” without a bender guitar on most gigs.
    My lounge gig “likes” my Chet.
    My other electric guitars don’t get nearly as much exercise as the avatar critter.
  7. brookdalebill
    Austin, Tx
    Hipshots, particularly the Will Ray model is a comparatively inexpensive introductory model.
    I have two guitars with them.
    My third has the slightly more expensive standard model.
    I’ve had lots of different model benders, but the ‘shots work for me.
    Shango66 and PlainAllman like this.
  8. Informal
    Informal Tele-Afflicted
    SoCal
    I have a Crook tele with a G-bender, and 6-7 other guitars.... I play the Crook way more than the others, but the rest of the herd is far from abandoned.
  9. PlainAllman
    Van Zandt Co, Texas
    Thanks for that info. I’m gonna look into it and maybe try it out in my Squier CV first before I consider making any permanent alterations to the AmPro. The Squier is already an experimental guitar.
    brookdalebill likes this.
  10. dickey
    dickey Friend of Leo's
    I had a bender, then sold it, figuring since I play pedal steel, why bother?
  11. tfarny
    tfarny Friend of Leo's
    Hudson Valley, NY
    I'm an on-and-off bender player (just the hipshot kind so far). So it's definitely not the only guitar I play, but when you need it, you need it! I play a hollowbody with Bigsby and a tele with Hipshot B/G (I don't use the G) most of the time.
    I find that G bending is mostly doable with good old fingers, it's the B bending that really adds character.
  12. Catatafish
    Catatafish TDPRI Member
    TN USA
    After seeing Jimmy play 10 Years Gone on one it's on my list of must haves.
  13. RollingBender
    RollingBender Tele-Afflicted
    SW Minnesota
    I feel limited if I don’t have a B bender on a guitar. The G is fun too but I can get by without it.
  14. Pineears
    Pineears Tele-Afflicted
    Except for some acoustic now and then, just play the B Bender for years now. Got rid of my Strat. Need to let my other Tele go and add another B Bender.
  15. 8trackmind
    8trackmind Tele-Afflicted
    Dark side of the moon
    B.
    I treat a b bender like a whole other instrument and practice it separately...and usually just country stuff. Its too easy to over-use a bender.
  16. Don Miller
    Don Miller Tele-Afflicted
    Anchorage, Alaska
    Actually my Nashville West string bender guitar has been in the case for about the last month...I have been working on my flatpicking, so my D-18 gets the practice time...I also have an Epiphone Sorrento I keep out on the stand when I feel like playing electric....
    Ive been thru these cycles before....One of these days I'll hear something...or come across something that will induce me to pull out the b bender....
  17. T Prior
    Charlotte NC
    why bother ?
    I own and play 2 x Emmons Steels , been on Steel since the mid 70's.
    BUT ... The Bender and the Steel are not the same Instrument, totally different. Sure some players can indeed mimic a PS but that gets old after 3 or 4 licks ! Very old. We can't play Mud on the Tires on the Steel ! Heck, we can hardly play it on the Bender !
  18. Skronkocaster
    Skronkocaster TDPRI Member
    Indianapolis
    I got the bender bug big time and now I hardly pick up a "non-bender" 6 string. It's deep enough that it's got me considering selling off a few "non-bender" guitars.
  19. hotraman
    hotraman Tele-Afflicted
    Camas, WA
    I own a 1999 Fender MIA Nashville B bender and love it. Along with my MIM Jazzmaster, I get most of my Fender tones ( No need for a Strat)
    My main guitar is my Black Falcon.
    And I play a little pedal steel guitar when asked.
    But .. my B bender will see some time in a few weeks ( playing outdoor church service in a tent)
    I was looking at used prices for B benders .. wow they have gone up.
    I try to play "clawhammer" style with my b bender, to get that pedal steel guitar sound.
    No plans to sell my B bender .. love this guitar.
  20. asatfan
    asatfan Friend of Leo's
    Beautiful Brown County, IN
    I play either my 89 Asat with an Evans Pull String or my 92? Asat Classic with an Evans Pull String. That doesn't necessarily mean I'm constantly bending. I actually use it very selectively. We have a really good steel player and I don't step on his toes. But, the only time I play a non-bender is when we're playing acoustic sets.
