Question about wattage and inputs
Discussion in 'Amp Central Station' started by ndcaster, Sep 15, 2020.
  1. ndcaster
    ndcaster Poster Extraordinaire
    Indiana
    hi all
    I'm thinking of purchasing a 50 watt RMS lithium-battery-powered amp
    it has three inputs: two 1/4" high-z in parallel, and one XLR
    my piglet-ignorant question is: if I plug in two acoustic guitars and a vocal mic, how loud is this amp likely to get before distorting?
    I have zero experience with battery-powered amps, but this thing really intrigues me
    matty428 likes this.
  2. FenderLover
    Minnesota
    Well, 50W is 50W (they say) regardless of how it is powered, and is really influenced by speaker size/number/efficiency for loudness and dispersion.
    What amp is it? Maybe someone here already has experience with it.
    mfguitar likes this.
  3. Abu Twangy
    Abu Twangy Friend of Leo's
    Philly
    The good thing is the amp is rated in RMS so a 50 watt RMS amp should be compartable to other 50 watt RMS amps with the same efficiency speaker.
    Reminds me of the battery powered Mike Matthews Freedom Amp of the early '70s. It was rated at 300 watts--300 watts PMP (Peak Music Power) so it was no SVT competition. And it took a small mound of carbon zinc batteries to power it.
  4. wabashslim
    wabashslim Tele-Afflicted
    Sonorous Desert
    Just remember the more signals going through, or the louder, the faster the batteries drain. Does it say it's 50 watts while on battery power?
  5. Leonardocoate
    Leonardocoate TDPRI Member
    Ohio
    Are talking about the Roland Street Cube? If so, the mic will be a separate channel...you will not have any distortion issues....Great amp....Like all things Roland
  6. schmee
    I have found two guitars in one amp to be gnarly. However, I'm speaking of old tube amps, not modern ones. Not sure about those.
  7. printer2
    Can't say anything with the info given. Some manufacturers are not truthful on their specs. Need to know the make and model.
    PhredE likes this.
  8. mfguitar
    mfguitar Tele-Afflicted
    Buffalo
    I was impressed with the Bose S1, plenty of volume and lightweight. They claim it lasts up to 11 hours, if it does more than 1/2 of that you would be fine. Downside is only 2 combo inputs so you would need to a small mixer. I am not a Bose fan but they sound great.
    ndcaster likes this.
