Question about Tru-oil
Discussion in 'Tele-Technical' started by mrplavick, Nov 29, 2008.
  1. mrplavick
    mrplavick TDPRI Member
    Maryland
    Hi all,
    I'm finishing a parts Tele with Tru-oil and it seems no matter what I use to apply it, bits of lint are left behind. I've tried well worn tee shirt material, wiping cloths made from tee shirt material, and circular finish wiping pads from Woodcraft. Seems like I can lift most of it out when I scuff between coats with a scotchbrite pad, but is there something I could be doing differently to avoid it in the first place?
    BTW - I'm following the procedure from LMII ( http://www.lmii.com/CartTwo/TruOil.htm ) i.e., wipe on a thin wet coat and then immediately wipe off the excess)
  2. rhh7
    rhh7 Tele-Afflicted
    Calgary, Canada
    I have always wiped it on with my finger, rubbing it into the wood as evenly as possible, going in one direction...like spreading out paint. I absolutely love this Tru-oil on a maple neck!
  3. sean79
    sean79 Poster Extraordinaire
    northcentral/western Pennsylvania
    I think I applied mine with my fingers and wiped it off with a paper towel. It's been a while, so I'm not exactly sure. I ended up taking 0000 steel wool to the final coat - not to remove lint - just to give it an even-looking satin finish.
  4. 6x47
    6x47 Tele-Holic
    Northern ON
    Don't worry about it. As the finish soaks into the wood, the lint is left high and 'dry' and is easily rubbed off just using a thumb or when you do the final polish.
  5. WrayGun
    WrayGun Tele-Afflicted
    Pittsburgh, PA
    I applied mine with a bag o' rags, basically just pieces of old t-shirts. I too had some lint issues, but just kept going, with some 0000 steel wool every few coats. I probably had a total of about 20 coats, and the final buffing left no signs of lint. Don't sweat it.
  6. SayWhat?
    SayWhat? Banned
    CA
    Use your fingers. I haven't used Tru-Oil on guitars, but have refinished several rifles with it, and fingers are the ONLY way to go for application. Finish off with steel wool, ending with OOOO, then "Stock Sheen & Conditioner" for the final finish.
  7. mrplavick
    Maryland
    Thanks everyone for the advice. I'll just keep at it with scotchbrite between coats. Hopefully I'll have some pictures to post soon.
    For those who apply with their fingers - what cleans it off?
  8. SayWhat?
    SayWhat? Banned
    CA
    I think I used stuff like "GoJo" oil-based hand cleaner (been a few years) but it's not hard to clean Tru-Oil off your hands.
    BTW, buffing vigorously with your fingers (build up some heat!) is a great way to buff it out. I used to do that between coats when it was on the verge of being dry, and you can really smooth it out that way.
  9. mellecaster
    mellecaster Former Member
    Desperadoville..USA
    +1...Fingers are Best...they don't leave lint...and for you Nancy Boys...Lava Soap will take it right off....it only hurts for a Teensy bit......;)
  10. mrplavick
    Maryland
    I put my next coat of Tru-oil on with my fingers and I had a lot more control of the application and no lint. Cleaned up with naptha. Thanks again.
  11. RomanS
    RomanS Poster Extraordinaire
    Vienna, Austria
    I also had lint problems when applying TruOil - I ended up using regular kitchen dish-cleaning sponges cut up into small pieces; they were only good for one coat each, as the sponges would harden up when the TruOil cured.
    Oh, and I cut the TruOil with turpentine (about 2:1), which made applying it easier...
