Question about the Tele Treble
Discussion in 'Telecaster Discussion Forum' started by ChickenKiller, Jun 8, 2010.
  1. ChickenKiller
    ChickenKiller Tele-Holic
    Oklahoma
    I am asking this question and I think I know the Incrediblly obvious answer...
    Got my first Tele in Feb... before that I played Acoustic.
    What I notice is when I play Barre Chrods up the neck my G B and Lil E strings are really pronounced... Especially the G string...
    Granted with just a slight Tone knob adjustment it cuts some of the Treble out...
    So I guess the obivious... Duh man it is a Tele?
    haha
    Thanks guys.
  2. Chewy
    Chewy Tele-Meister
    NY, USA
    So what's the question?
    ...you can try adjusting the screws around the bridge pickup to lower the treble side or raise the bass side to taste.
    ...the G is the loudest string on an electric, so this is to be expected to some degree. you can get string sets with a wound G for a more balanced sound and acoustic feel (I hate them personally but others like'em!)
  3. Flewis
    Flewis Tele-Holic
    woodstock ontario canada
    you didnt say what type of bridge you are using but steel saddles would be brighter sounding, you could switch to brass. I always found the same problem with tele's until I found the seymour duncan 5-2 pick up it evens it out really nice
  4. Detman101
    Detman101 Banned
    Frederick, MD
    Just be aware that the wound-G does not bend like the plain-G.
    you have to bend it twice as far to get the same effect as would happen on a plain-g string. That's the reason why I went back to plain-Gs.
    Dm
  5. Tele Jr
    Tele Jr Tele-Holic
    Minneapolis, MN
    Flat Pole vs Raised Pole...
    You will get a different balance with a flat pole bridge pup, vs a so called raised pole pup. If you have a raised pole unit now consider checking out a flat pole pup.
  6. sjtalon
    sjtalon Doctor of Teleocity Ad Free Member
    Upper Peninsula of Michigan
    I agree with the adjustment of pickup height suggestion.
    Get them lower, and play around with if for a while, you can fine tune tone quite a bit with pickup heights.
    What Tele do you have ?
  7. jefrs
    jefrs Doctor of Teleocity
    Newbury, England
    imo a tele on the bridge pickup with the tone control on 10, should sound like breaking glass when spanked.
    Adjust the pickup heights to balance them out and find the sweet spot.
