Question about nut spacing
Discussion in 'Tele-Technical' started by sleazy pot pie, Mar 1, 2021.
  1. sleazy pot pie
    sleazy pot pie Tele-Afflicted Gold Supporter
    austin
    I am putting together a telebird. I bought a precut nut, but I am wondering if maybe I need one with a little wider spacing .
    The strings seem to be a little far from the edges and it’s not quite a straight line over the nut to the tuners.
    This will be the first time I have done any nut work. I bought a set of nut files, and have read a ton, but have no hands on experience.
    Am I looking at this right?
    Boreas likes this.
  2. Boreas
    Boreas Friend of Leo's Silver Supporter
    Adirondack Coast, NY
    It is a low resolution image, so kinda hard to tell fore sure, but it looks OK to me. I don't like my strings much closer to the edge. I wouldn't worry about the straight line to the tuners. That is more a function of tuner spacing and not the nut.
    I try to make the gap from the edge of the fingerboard to the string roughly equal up the neck. So the saddle placement also plays a role in string spacing at the nut, at least for me. There are many different preferences out there.
    On a fingerboard that has quite rolled edges, one typically wants the strings a little more inboard. I roll many of my fingerboards.
    Is your pre-cut nut for a lefty or righty? Was it cut for a flipped Firebird, or a Fender? Was it pre-slotted, or just marked and you cut the slots? Spacing is usually different on a RH nut than a LH nut, depending on your string layout.
    This is a factory nut from a MIM Thinline Reissue neck:
    sleazy pot pie likes this.
  3. sleazy pot pie
    austin
    Thanks for the insight.
    It is a right handed nut/reverse headstock.
    It is a pre slotted bone nut from eBay somewhere.
    I will try to get a better shot tonight.
    I just took a quick snapshot on my way out the door this am to look at it while on break at work.
    I have a couple more of these nuts, some 42 some 43 and some 44
    Not sure which this one is.
