Question about Blues Cube Hot (Live volume)
Discussion in 'Amp Central Station' started by Dr Improbable, Oct 17, 2019.
  1. Dr Improbable
    Dr Improbable Tele-Meister
    Wisconsin
    I've got one here, and I'm thinking of lugging it outside the house for gigs or jamming. Blues mainly, maybe some classic rock.
    Anyone here do any small venue live work with a Blues Cube Hot?
  2. Mr_Martin
    Mr_Martin Tele-Afflicted
    Cologne, Germany
    30 Watts should be enough.
    Dr Improbable likes this.
  3. Dr Improbable
    Wisconsin
    30 watts tube, sure. But this is something else.
  4. Mr_Martin
    Cologne, Germany
    30 Watts are 30 Watts.
    The Tube vs. Solidstate discussion is older than the Dinosaur era.
    Most of the modern non tube amps are equal in loudness.
    For bigger stages you have a P.A. System.
    Greets
    tidalcast and Dr Improbable like this.
  5. markal
    markal Tele-Holic
    Colorado
    Yes. I jammed in small spaces with a BCH and it was plenty loud. I now have the Artist version and run it on 15 watts for decent sized bars. I’m pretty sure others here and over at TGP gig both the Hot and Artist on 15 watts.
    TeleTex82 and Dr Improbable like this.
  6. Blrfl
    Blrfl Tele-Holic
    Northern Virginia
    Watts are useless as a measure of sound pressure level. An amp that produces 30 at the speaker terminals will make less noise through an inefficient speaker than an efficient one.
    The same goes for light bulbs. Those are properly measured in Lumens.
  7. Mr_Martin
    Cologne, Germany
    If Watts are useless as a measure, what are we then talking about?
    Is a 50 Watt Amp louder than a 100 Watt? :)
  8. Dennyf
    Dennyf Tele-Afflicted
    Charlotte, NC
    @Blrfl said watts were only useless as a measure of SPL. They are actually a unit of power dissipation, which is a factor in SPL, but not the only factor.
    A 50 watt amp driving a 4x12 cab with efficient speakers WILL be louder than a 100 watt amp driving a low-efficiency single-12. So it depends on the whole “soup,” not on just how many electrons the amp is pushing.
    I, too, am in the “watt-is-a-watt” camp. That’s why it pains me so much to have to acknowledge that my little 15 watt Pro Jr (tube) is probably just about as loud as my 60 watt Trademark 60 (solid state). That’s just an example, over 40 years of experience have demonstrated to me that watt-per-watt, valve amps generally seem louder. I believe this is partly due to a different standard in acceptable THD between the two, and that SS devices plateau at their rated output, beyond which they just clip.
    Dr Improbable and Blrfl like this.
  9. Mr_Martin
    Cologne, Germany
    I'm also playing guitar for over 40 years an i must disagree with you.
    Do you ever played a (SS) Peavey Bandit.
    Peavey Watts are real Watts!!
    Also the Marshall SS Amps are very loud.
  10. schenkadere
    schenkadere Friend of Leo's
    NY
    @Mr_Martin You probably played better tube amps compared to the SS you tried.
  11. Mr_Martin
    Cologne, Germany
    Not better, just different.
  12. Dr Improbable
    Wisconsin
    That's all I needed to know, thank you!
    tidalcast likes this.
