Putting together my first parts build
Discussion in 'Other T-Types and Partscasters' started by Aaron1061, Oct 18, 2019.
  1. Aaron1061
    Aaron1061 Tele-Holic
    Troy, AL
    The allparts neck doesn't fit quite snug in the pocket. There is a gap on the right and bottom left. Will this be alright?
    Got the loaded body and neck on reverb at a pretty significant discount so if it's "good enough", I'll be okay with it. This will be a place holder tele while I save up to have one built. [​IMG][​IMG][​IMG]
    Sent from my Pixel 2 XL using Tapatalk
    baiff, Jim_in_PA and nojazzhere like this.
  2. G.Rotten
    G.Rotten Tele-Holic
    CoolsVille
    That'll be fine. I've had better & ive had worse. All were fine.
    A tight pocket is ideal, but more important is just being able to tighten the neck via the screws. So a proper flat bottom is key to keep the neck from moving. If you had a tight pocket & poor heel to bottom contact the neck would shift anyway damaging the pocket.
  3. Freeman Keller
    Freeman Keller Tele-Afflicted
    The important thing is that the E string lines are equidistance from the edges of the fretboard - in other words, the neck isn't twisted from side to side. When you drill the holes in the neck make sure it is dead centered.
  4. Treadplatedual
    Treadplatedual Tele-Holic
    Indianapolis, IN
    That's a fine gap. Keep in mind, if it's too tight, weather changes can crack finish.
    Dan German and Aaron1061 like this.
  5. Aaron1061
    Troy, AL
    Not worried about that. It's already been relicd
  6. guitarbuilder
    guitarbuilder Telefied Silver Supporter
    You want some wiggle room to get the e strings aligned to your liking. A snug neck pocket won't allow for any adjustment that way. Allparts necks are very nice for the money. It looks like it may be a Guitar Fetish body and they aren't noted for always fitting to Fender specs.
    Aaron1061 likes this.
  7. Milspec
    Milspec Friend of Leo's
    Nebraska
    Every single Fender 50's Baja came from the factory with a bigger gap and is still considered one of the best bang for the buck Fender ever built. It is fine.
    TeleTown likes this.
  8. Aaron1061
    Troy, AL
    Good eye! I believe it is a GFS.
  9. t-ray
    t-ray Tele-Holic
    Gotham City
    I would only add, that is a fine looking T-Type. Beautiful board on that neck. Enjoy.
  10. skerwo
    skerwo Tele-Holic
    near Munich, Germany
    Seems to be absolutely ok. Nice looking guitar!
  11. Ronkirn
    Jacksonville, FL
    very good.. a good leveling is a good part of a successfully optimized set-up.
    r
  12. Aaron1061
    Troy, AL
    Almost done [​IMG]
    baiff likes this.
  13. RodeoTex
    Nueces Strip
    That gap isn't bad at all. The original Teles were all over the place. I suspect many current customers would have returned them in these days.
  14. ben smith
    ben smith Tele-Holic
    london
    I think that looks great!
  15. Aaron1061
    Troy, AL
    I'm a little embarrassed to say, but I've been stumped all afternoon. I got everything shielded and wired up with the cavaliers, and when I touch the bridge pole pieces, I get hum. I have been checking solders and everything for hours. I have the shielding grounded and I have robs pickups grounded with his 3rd wire ground. Back of pots.
    Any ideas?
  16. guitarbuilder
    jack wires backward?
  17. Aaron1061
    Troy, AL
    Update: Quiet as a mouse, sounds GREAT, and plays even better.
    ben smith likes this.
  18. Paulie_Boy
    Paulie_Boy Tele-Meister
    Man, that's some fine eye candy right there. Play it in good health!
