Putting capacitor in NFB?
Discussion in 'Amp Central Station' started by alexwilds, May 6, 2021.
  1. alexwilds
    alexwilds Tele-Meister
    Japan
    I am trying to get some of the shrillness out of my 5F1 Champ, as well as the high pitch whine and buzz. Would putting a small cap, say, 150pF across the NFB resistor do the trick? Anybody ever done that?
  2. jimgchord
    jimgchord Tele-Afflicted
    victor,ny
    There shouldnt be shrillness or whine or buzz. May want to address the actual problem instead of putting a band aid on it.
    corliss1, Fendereedo and oldfish like this.
  3. Lynxtrap
    Lynxtrap Tele-Holic
    EU
    While I agree with the above, the answer is yes. You can put a capacitor across the NFB resistor to cancel high frequencies. To what extent it does the trick in your particular case is uncertain.
  4. Guitarteach
    I made my NFB variable on a pot... acts like a presence control. I could add a cap too but the variable resistor lets me dial in more NFB which softens it anyway. Cranked it might be less shrill, so i can adjust too.
    As mentioned, be worth locating buzz/noise issue, if elsewhere.
  5. dan40
    dan40 Friend of Leo's
    Richmond Va
    Is this a vintage amp, newer reissue or a kit that you built? The squeal could be caused by several issues that are easy to fix once we know what your amp is.
  6. alexwilds
    Japan
    In a perfect world, you are right. In Japan there are no three wire outlets, so lousy grounding wherever you go. That and florescent lights are almost universal, as is the resulting high pitched whine they cause. Rather than rebuild the society and re-wire the nation, I'll go with the band aid - LOL!
    Big-ez likes this.
  7. alexwilds
    Japan
    5F1 Champ, home brew, build from the scraps of other home brews. I have several very straight, wonderful performing amps, both factory and home built, that I do not mess with. And then I have several frankenstein/ test bench amps that spend a few months as 6V6 push/pull, then as twin 6L6 single-ended with a fixed bias, etc. I have decided to restore this one back to stock, and out it in the stop-fixing-it collection of working amps.
    And then, of course, I'll build a new frankenstein.
    My problem is not the amp, rather funky two-wire electrical grid, lots of florescent lights, etc., cause background hum. I need lots of shielding around here.
  8. jimgchord
    victor,ny
    Does any type of line conditioner help?
  9. dan40
    Richmond Va
    @alexwilds ...Has the squeal been occurring since the very first power up after the build? Just wondering if the NFB circuit is creating positive feedback which could be fixed with a quick swap of the OT's primary wires.
