Put my Speakers in "series" or "Parallel&quot
Discussion in 'Amp Central Station' started by BADFISH, Apr 13, 2003.
  1. BADFISH
    BADFISH Tele-Meister
    Daytona beach Fl. and Austin Tx.
    I have Two (8 ohm each) speakers I need to Run with an 8ohm Head.....Do I run these Speakers in "Parallel" or "series"? Thanks for any and all info.
  2. telest
    telest Tele-Meister
    You will have to connect them in series which will be a 16 ohm load. A parallel connection will give you a 4 ohm load which will burn up your 8 ohm output transformer. Though the 16 ohm load is safe for your amp you will lose some efficiency i.e. less volume, may not achieve ultimate tone potential etc... Good luck.
    Steve
  3. EMan
    EMan Tele-Holic
    Dallas, Texas
    It depends on if the amp is a SS amp or tube (output stage).
    The general 'rule' is that with a tube amp, 1/2 the specified load is okay. With SS, you cannot go lower that it's rated load.
    With tube amps, raising the output load will raise the amount of 'reflection' back to the output tube's plates. In a 2X6V6; 8 ohm amp for ex, the OT has a voltage ratio of ~35:1. This means that what ever voltage is developed by the speaker is multiplied by 35 at the output tubes. Effects are generally arcing. You may see that some tube amps have a series of diodes in the plate circuit to protect the tubes. Also note that most Fener speaker jacks are shorted when nothing is plugged into them.
    SS amp are basically; the lower the load, the more current comes out. Tends to burn them up of the load is to low.
    There's also some sonic differences between series and parallel connections.
  4. telest
    telest Tele-Meister
    Eman, I was not aware of the 1/2 load theory. I always thought tube amp output transformers were pretty sensitive, but I'm definitely not an authority on amp workings. Just basic knowledge.
    Steve
  5. BADFISH
    I wonder why Weber is selling These speakers???(ohms)
    I just bought (2) F-150's (C12N), for an 8ohm (vintage fender) amp. I told him "the amp is 8ohm., and its a 2X12 Cabinet......." he sent me two 8 ohm speakers???? My friend also just bought two "Blue dog" speakers for his 8 ohm head, he also received (two) 8 ohm. speakers????????? Is this Wrong? should I have received two 16 ohm speakers and put them in "Parallel "for 8 ohms? Thanks for the help
  6. EMan
    EMan Tele-Holic
    Dallas, Texas
    Another benfit to parallel wiring is; if you toast a speaker, there will still be another speaker hooked to the amp. In a series connection, a blown speaker will disconnect the cab from the amp.
    BadFish, it is always best (as mentioned) to keep the load matched to the source. If you're running an 8 ohm head, and you have a two speaker cab...the cab needs to be 8 ohms.
    When you order speakers, you have to be very specific about what your requirements are.
    If you want to wire them in series, order 4 ohm speaker, in parallel; 16 ohms.
  7. BADFISH
    It's odd he sent 8 ohm
    I told Them The Exact head and 2X12 I would use these speakers with, the same goes for my friend(Who orderd the Blue Dogs) That is the great thing about "Weber" They get all the info. from you, and ask alot of questions. He thought these would be the Best speakers for the sound I needed/with this Cab and amp? He's The Guru??? Thanks again for your help
  8. jimmiboots
    jimmiboots Tele-Meister
    Jacksnoville/RIVERSIDE
    Weber speakers and loads...
    Hello everyone, I'm Bafdish's friend. I also ordered speakers from Weber. I specificaly told him, "I'll be playing through a blonde '62 Bandmaster running at 8ohms. I use a 2x12 Marshall cab, which I play at high volumes, sometimes I step on a Big Muff and get pretty crazy. What speakers do you reccomend?" We then talked about the type of tone I was going for, and he recomended one CF150 and one CF150b. Both the speakers he sent were 8ohm speakers. I often do dime my amp (well at least 8 or 9 it). Am I in danger of damaging my amp and/or speakers?
  9. Big Cookie
    Big Cookie RIP
    Ennis, Texas
    Easy guys
    The 62 Bandmaster is the 6G7-A chassis which has an output transformer for a 4 ohm load. Wire em up in parallel. It was the 1961 6G7 chassis that was designed for an 8 ohm load. Fire it up and play it loud and proud.
    Best Blues,
    Cookie
  10. jimmiboots
    A "load" off...
    Hey, all right. My bandmaster actually has a Kendrick OT. I reckon I should check the numbers on it and check the specs. Does anyone know if there's anywhere online I can get specs on Kendrick stuff? (by serial numbers, etc.) Also, please don't get me wrong, I'm NOT trying to badmouth Weber. I've had 2 pairs now and they all sound fantastic. By far the best for my $.....
  11. EMan
    EMan Tele-Holic
    Dallas, Texas
    For general info: I've been playing my brown Princeton into 4 ohms on and off for about 35 years.
    At present, it's pushing a Weber P12N (repro baffle), and a Celestion Vintage 30 in a Jenkins 1X12 cab.
    Take a peek: http://members.tripod.com/~flh1968/fender.html
    BTW, Cookie has always given my great suggestions where speakers, tubes, etc. are concerned. This amp has never sounded better.
  12. BADFISH
    Thanks for the Info.
    I was told the Blackface Bassman, Bandmaster etc. had a 8 ohm. Tansformer.............With your help and the "Fender Ampfield guide".........I now know it's 4 ohm. That should have been my first quistion, then take it from there...........Thanks again
