Purple stratocaster
Discussion in 'Tele Home Depot' started by joekumpan3, Nov 19, 2014.
  1. joekumpan3
    joekumpan3 Friend of Leo's
    Kaneohe Hawaii
    Thank you, plenty of other crooked things and defects. Thanks though.
  2. barbrainy
    barbrainy RIP
    Northampton, UK
  3. joekumpan3
    Kaneohe Hawaii
  4. joekumpan3
    Kaneohe Hawaii
    I made a little shim out of an old credit card with a lot of good times from it. Hopefully a little mojo from it will transfer over.
  5. joekumpan3
    Kaneohe Hawaii
    It fits the neck pocket just right! The card may seem kind of thick but the tremolo could use a better break angle so I went high.
  6. joekumpan3
    Kaneohe Hawaii
    The ground wire gets soldered to a piece of copper tape.
  7. joekumpan3
    Kaneohe Hawaii
    And it goes here.
  8. joekumpan3
    Kaneohe Hawaii
    I bought strap locks to recess but am having a hard time bringing myself to drill that big of a hole and then an even deeper screw hole. Maybe in the future, for now standard strap locks.
  9. joekumpan3
    Kaneohe Hawaii
    So I got everything buttoned up and soldered etc. so I put one string on to check and........ nothing. I have to go back and check the connections.
  10. joekumpan3
    Kaneohe Hawaii
    I forgot to put a wire from here
  11. joekumpan3
    Kaneohe Hawaii
    to here. I guess the volume really has to be attached to the switch in order for it to work.
  12. joekumpan3
    Kaneohe Hawaii
    I need to fine tune the nut, there are still some sharp corners on the frets, adjust the tremolo saddles but I am basically done. I couldn't resist a little two string jam I just really wanted to hear the pickups.
    They sound good on the bass strings. I dialed the jcm 900 up to max gain and they sound good but when I dial it down a bit they sound better. There is a little buzz and I think if I flatten the ground wire solder a little it will go away if not I will wrap it around a screw or something.I will finish up this weekend and post video soon.
  13. joekumpan3
    Kaneohe Hawaii
    I decided to man up and and install the recessed strap lock inserts. It was kind of hairy and definitely irreversible here is the hole for the rear.
  14. joekumpan3
    Kaneohe Hawaii
    I had to remove the neck to get to the front at the right angle.
  15. joekumpan3
    Kaneohe Hawaii
    Here is the front installed it sticks out on the curve a bit but that will help keep the strap away from the bod a little.
  16. joekumpan3
    Kaneohe Hawaii
    Here is the rear,it's money !$!
  17. joekumpan3
    Kaneohe Hawaii
    Here is how much clearance there is wi the the front.
  18. joekumpan3
    Kaneohe Hawaii
    And the rear. I like them very streamline and cool.
  19. joekumpan3
    Kaneohe Hawaii
    I bent the ends of the strings and soldered the wraps.
  20. joekumpan3
    Kaneohe Hawaii
    I adjusted the saddles to approximately where they should be.
