So in March (which seems like an age ago -- what a long strange trip it's been) I ran a thread where I tried to draw my first-build 5F2a as it ended up, mods, mistakes and all. Humorous but humbling to see how much I couldn't remember and couldn't reconstruct from photos.
I decided the layout might be more useful to someone someday if I drew it to be more generic -- no sonic mods, but some circuit modernization.
So after a few more hours in DIYLC, here's a first draft. First draft. Not final. Not correct. Not for saving, sharing, or building amps from...
If the image doesn't blow up enough, here's a Dropbox link to the full-size JPG.
As always, thanks to @robrob , whose kind sharing of his great DIYLC files gives me a framework and lots of ideas.
Notes:
I've moved the HT CT to the reservoir negative pole as Rob has now started doing (more info here), and furthermore now return the ground wire from the second cap, which I *think* was suggested as an incremental improvement in a recent thread (see posts 11 and 14 here).
I kept my shielded inputs to the V1 grids. Not necessary, though. I kept my 68K grid stoppers on the input jacks for the same reason. Not necessary. I show an elevated heater CT, because it's so easy in this amp. I kept my MF resistors in the input chain because it does really reduce hiss. Not necessary. I show a 10W bias resistor -- 5W or less can be used -- and made mine wirewound because quiet and robust. Not necessary.
Questions:
Any chance I actually got the grounds right from the output tube bias resistor and the NFB sector? As you'll know, this is not how Fender did it, but I'm trying to keep the output tube grounds together and the preamp grounds together.
And what did I screw up?
Notes:
Questions:
