Proluxe with Tweedle Dee
Discussion in 'Shock Brother's DIY Amps' started by hackworth1, Feb 13, 2018.
  1. hackworth1
    hackworth1 Friend of Leo's Vendor Member
    Volusia County, Florida
    qwertyuiop 045.jpg qwertyuiop 047.jpg qwertyuiop 054.jpg qwertyuiop 055.jpg qwertyuiop 056.jpg
    akuster777 and robrob like this.
  2. hackworth1
    This project utilizes the standard 5E3 board from a Boot Hill kit. I wanted to see if I could fit the Tweedle Dee Circuit on a typical board. I also installed an adjustable fixed bias circuit on the left side.
    Mr Ridesglide likes this.
  3. theprofessor
    Chattanooga, TN
    Nice, Dave! Great to see that you can fit the Tweedle Dee on a typical board of yours! Cool!
  4. screamin eagle
    screamin eagle Poster Extraordinaire
    S. CA
    What is the tweedle dee circuit?
    Mike Simpson likes this.
  5. D'tar
    D'tar Friend of Leo's
    WNY
  6. robrob
    United States
    I like the idea of using a trimmer for the phase inverter balance control.
    JD0x0 likes this.
  7. JD0x0
    JD0x0 Poster Extraordinaire
    New York
    It's fairly common in D style amps (especially with LTPI) and IMO, a major part of one of those 'small things' that makes the Dumbles stand out from 'regular' amps. I have a PI balance pot on my twin, with some other Dumbly tweeks. You can run it clean and get that sustaining feedback-y bloom stuff super easily. The amp just seems to want to blast off. It takes some tuning, though, and I don't have a scope to do it on, so I typically have to tune by ear, for this part. On a scope, you're looking for enough imbalance that the 2nd order harmonics stop being suppressed in the PI. (A perfectly balanced PI will cancel some noise and even order harmonics in the PI) The added even order harmonics in the output section seem to make the amp have much of that 'singing' quality.
    FenderLover and sds1 like this.
  8. Mr Ridesglide
    Mr Ridesglide Friend of Leo's Silver Supporter
    Bloomington, MN
    Hope we can get a test drive sound clip of this one Dave. Very innaresting indeed!
  9. hackworth1
    bassforsaletweedledee 002.jpg bassforsaletweedledee 003.jpg bassforsaletweedledee 004.jpg bassforsaletweedledee 005.jpg
  10. hackworth1
    Objective to increase clean headroom with more filtering - ergo a 32/32 uF F&T cap can in the rectifier hole. Solid State rectifier is built with four N4001 diodes on a terminal strip to convert AC to DC. A 270 ohm 10 W resistor is in place for the sake of R/C coupling.
    robrob likes this.
