Blueslover88
Hey guys,
Built Rob's 5e3 micro this time with two EF 80 in push pull for power tubes. I used the musical supplies site for the iron. Both the 190-0-190 pt and OT5PP output trans. I only connect the black 0 ohm and 8 ohm wire to a single output jack. The amp sounds okay, not as good as I want yet or as good as my 5e3 micro with the 12au7 power tube. I also get a wierd squeel/hiss (oscillation?) When any of the three controls hit max. Turn them down from max to nine or less and it goes away. Does it with or without guitar and swapping OT wires to the plates had no change. My voltages are a touch lower then some other EF 80 builds ive seen on here but they used the 200volt toridial PT and I'm only using 190 regular PT. Any more infor you need to help me out.? All built to specs on @robrob site thanks for help in advance
