Problems with a 4-way wiring
Discussion in 'Tele-Technical' started by reteps4002, Oct 23, 2019.
  1. reteps4002
    reteps4002 TDPRI Member
    NYC
    I recently decided to upgrade my kit built tele to have a 4-way switch. I wired up the switch (OAK Grigsby) according to the fralin diagram. I have triple checked the switch wiring and it matches the diagram. The problems arrived when I tested the new wiring. When I put the switch in the bridge only position it works fine but I get no signal at all from any of the other switch positions. I did go through the steps to split the neck coil from the cover. Is there a short or loop somewhere that I’m not seeing or did I not ground the cover correctly?
  2. Steve 78
    Steve 78 Friend of Leo's
    Melbourne, Austraila
    Buy a multimeter (you can get cheap ones for around $10) and do a continuity check to make sure the all the connections are correct and nothing is shorted unexpectedly in each switch position. It's much more reliable than using your eyes.
  3. Urshurak776
    Urshurak776 Tele-Holic
    Charlotte
    Seconded. Use a multi-meter to verify connections. I have been fooled many times.
  4. Peegoo
    Peegoo Tele-Meister
  5. moosie
    Western Connecticut
    How could we possibly tell? Post the diagram you worked from. Post a non-blurry pic. Then we may be able to help.
    Multimeter is always the right choice.
  6. Peegoo
    Peegoo Tele-Meister
    Another possible cause: one of the solder terminals on the switch or perhaps one on a pot is in contact with the control cavity’s shielding paint/foil.
