Problem with Tone Pot
Discussion in 'Tele Home Depot' started by Lostininverness, Sep 20, 2020.
  1. Lostininverness
    Lostininverness Tele-Meister
    Christchurch, NZ
    Hi team,
    I've got a wiring issue. There is no change to the tone control when I turn it, and the volume cuts out at one end. I've checked the wiring against the layout, and fairly certain that I've wired it as per plan, and the cap leg coming off the wiper is shrink wrapped and not touching the pot casing.
    I was wondering if the wiring diagram has the tone cap coming off the wrong lug on the pot? Does it look correct?
    Cheers
    Grant
    crazydave911 likes this.
  2. hamerfan
    hamerfan Tele-Meister
    Germany, Bavaria
    Yeah, correct if you grounded the first lug. Tone pots can be wired in different ways. Otherwise defective cap or defective pot (overheated?).
    Lostininverness likes this.
  3. peterg
    peterg TDPRI Member
    Toronto
    That tone pot wiring does look odd. Try moving the wire from the volume pot to the lug to the left of the Tone pot middle lug.
    Lostininverness and crazydave911 like this.
  4. Peegoo
    Peegoo Friend of Leo's
    Wyoming panhandle
    That diagram is wrong.
    A properly-wired tone pot has none of the three lugs grounded to its case.
    It should be wired like this:
  5. Ronkirn
    Ronkirn Doctor of Teleocity
    Jacksonville, FL
    Let's see some photos of what you have..
    r
    Lostininverness and Boreas like this.
  6. Boreas
    Boreas Tele-Afflicted Silver Supporter
    Adirondack Coast, NY
    Almost sounds to me like the cap is not in the circuit. Try re-flowing the solder on the cap connections. If that doesn't work, check the values of the cap and pot and make sure they are still functioning correctly and have not been roasted. If that shows nothing, try @Peegoo's suggestion above. I have never used a 5-way in a Tele, so there may be something I am missing.
  7. RogerC
    RogerC Poster Extraordinaire
    Oklamerica
    ^ This
  8. peterg
    peterg TDPRI Member
    Toronto
    That’s what I was trying to say! A picture is worth a thousand words and all that.
  9. Lostininverness
    Christchurch, NZ
    Hi Peegoo, that lines up with what I was seeing on the interweb as well. I'll give it a nudge and see how it goes.
    Cheers
    Grant
    crazydave911 and Peegoo like this.
  10. Lostininverness
    Christchurch, NZ
    hmm, was going to post a pic, but its a small control cavity and a lot squeezed in. A bit hard to see the wiring. Will post a finished pic when all working - which will hopefully be soon!
