Pro Reverb Voltage Issues
Discussion in 'Amp Tech Center' started by bblumentritt, Dec 29, 2020.
  1. bblumentritt
    bblumentritt Tele-Afflicted
    Austin, Texas
    Here's one for you...
    Guy brings a Pro Reverb type amp in for service, says one 6L6 won't light. Sure enough, with the power on and in standby, there's no light on one power tube.
    I pull the two 6L6's and sure enough, one the dead one pin 2 to pin 7 is open. Okay... new tube time.
    Or so I thought.
    Go to test voltages....
    With no power tubes, the PT is putting out about 525VDC... should be about 460-480... but here's the bias tap is -120V, and that's before the 470Ω bias dropping resistor.!!
    With the power tubes in, the plate voltage drops to 318VDC with like -150V at the bias junction. Should be 440V at the plate and -51V at the bias point.
    It's a standard 325-0-325 V, 370 VDC @ 200 mA (DC) with 50 V bias tap.
    My first thought is bad tranny...
    Thoughts?
  2. bblumentritt
    Austin, Texas
    Open heater on one power tube... blown HT fuse.
    Fixed.
    dan40 likes this.
