mattmayhem
So I recently decided to gut my Fender Pro Junior and convert it to a Fender Princeton Reverb without the trem or reverb based on this project on Rob Robinette's site and this thread here on the forum. I had to modify the EQ section to work with the single tone control so I swapped it to the tone circuit used in the Harvard and Tweed Princeton. Finished this morning and after walking through Rob's startup procedure and checking voltages along the way (nothing unexpected based on the Princeton Reverb schematic), there are a couple issues:
1. The amp is crazy gainy! It has even less headroom than the original Pro Junior circuit. Already starting to overdrive when it's barely cracked on.
2. It also has a high noise floor. Doesn't really sound like 60hz hum to me, but more like something is acting like an antenna in the circuit? Dead quiet with the volume knob down, but comes in as the volume is brought up and is shaped by the tone. Does that mean the noise is coming between the input and the volume? I used shielded cable to the grids of V1 with the shield grounded on one end to the input jack.
All that being said, it sounds great with the volume on the guitar rolled wayyy down (doesn't change the noise floor, but otherwise). Wondering if anyone has insights as to why this modified circuit would have so much gain compared to the original Princeton Reverb, or if there are any suggestions for reducing the gain. I know I can swap the negative feedback resistor to a 2.7k, but I'm pretty sure that isn't going to do enough. I tried a 12AY7 in V1 and it sorta worked. dropped the noise floor significantly, but was still overdriving really early on the dial and lacked the punch and snap of the 12ax7 when the guitar volume was rolled down. Anyway, would love to hear any thoughts or suggestions on troubleshooting or reducing the gain. Thanks!
