Pro Jr. Question
Discussion in 'Amp Central Station' started by Frisco 57, Oct 9, 2020.
  1. Frisco 57
    Frisco 57 Tele-Meister
    Arlington WA
    I've had a US made Fender Pro Junior from '94 for a few years but not played it much until recently. It's loud and has great tube sound, especially for a small amp but has always had a strange sounding harmonic as the note or chord deteriorates. I've removed the middle chassis screw from the back panel because I've heard that can be an issue. Today I removed the springs and bracket that keep the power tubes in the socket. That I think, actually helped. Has anybody heard of that? Are there any alternatives to keeping the power tube from falling out of the sockets? BTW it's got fresh J J tubes in both pre-amp & power amp.
  2. DrPepper
    DrPepper Friend of Leo's Ad Free Member
    Unbound tubes always sound best to me. I could see the springs and caps being problematic if there was a microphonic tube in the amp.
    richey88, Frisco 57 and Fiesta Red like this.
  3. richey88
    richey88 Friend of Leo's
    philly suburbs
    No like-a the tube cages. Free them!
    Frisco 57 likes this.
  4. Dacious
    Dacious Poster Extraordinaire
    Godzone
    Quite possible a harmonic vibration from the spring keepers. Couid be a loose element in a tube.
    I've had two power tubes and a rectifier that 'sang' on certain notes.
  5. sluglas
    sluglas Tele-Meister
    mattituck
    I played a pro Jr in a band for years. Pro Jr's are biased hot And if you gig alot you can expect to change the tubes every year.
    When I first bought mine one tube last a day. Load it up with pro Jr set of JJ's from eurotubes. My brother and I both used Pro JRs in our band and guitarists would ask if that was all we were using. In regular bar situations they worked fine unmiked. Volume never went past 4.
    Change the tubes!!!
  6. corliss1
    Lansing, MI
    An amp from 94 is due for a full service, which may or may not include tubes.
  7. Marc Morfei
    Marc Morfei Friend of Leo's Silver Supporter
    Wilmington, DE
    I have had a PJ two different times. Both times the tube retainer rattled/buzzed annoyingly. Just take it off. It really doesn't do anything anyway. The tubes are not going to fall out.
  8. cincyguitarplay
    cincyguitarplay Tele-Meister
    ohio
    My Pro Jr from back in the 90's has always sounded bad....even with new tubes...but can't bare to get rid of it...buzzes..rattles...you name it:eek:
  9. Daytona.57
    Daytona.57 Tele-Meister
    Calabogie, On, Canada
    I use my Pro Jr IV Tweed, as a head for a 1X12 cab.
    I bought a fan from Walmart, $14.99, and it reduced the chassis temperature by 30°F. This extends the Life Cycle of the tubes and PCB.
