Printing a pdf full size
Discussion in 'Tele Home Depot' started by Chordophonic, Nov 12, 2015.
  1. Chordophonic
    Chordophonic Tele-Meister
    Isle of Wight UK
  2. skippolony
    skippolony Tele-Meister
    Liverpool. UK.
    I had the same problem until some very helpful members informed me I had to update my adobe reader and then change the print size to poster which then printed full size.
  3. amplifiedhermit
    amplifiedhermit Tele-Meister
    Western US
    Try this PDF I've attached. I opened your original file in Illustrator and set it up as 4 overlapping 8.5x11 inch pages. Make sure you print at 100% size as opposed to letting the printer scale it down, because its okay if a little gets cut off on the edges. (Edit: I assumed you wanted Letter size, but I've also added one in Legal (8.5x14) that has 3 vertical strips).
  4. netgear69
    netgear69 Tele-Afflicted
    england
    Hit print then (Size) (Actual size) (Poster).. the PDF in question will print 12 pages in A4
  5. tintag27
    tintag27 Friend of Leo's Silver Supporter
    Old England
    Make sure you have at least 2 measurements you can physically check on the printouts with a good ruler - one in the string direction, and one across the body direction...
    Most home printers I have owned did not print absolutely precisely, and some not even in pro, so that a measurement in one direction might be 99.5% accurate and in another direction might print 99% correct. In normal use this is not a problem, but when you are piecing together tiled output up to guitar size you could be out enough to encounter intonation problems in your build. Consider getting a bureau to output a one piece print...
  6. Chordophonic
    Isle of Wight UK
    Thanks to everyone who replied, much appreciated!
  7. trev333
    Coolum Beach,Australia
    I use the assembled printouts for my outline....as long as the small black square is exactly right size...and some basic length/width comparisons made..... I sand my outer perimeters so they get some variance anyway.....
    . I never use a printout for accurate measurement/placement of parts/routs....
    I measure each body/rout/screw hole as I go, for accuracy.... always having the bridge/neck I'm going to use on hand....
  8. RickyRicardo
    RickyRicardo Friend of Leo's
    Calgary, Alberta
    For the larger plans I go to a print shop like Staples. Stitching together 12 pages is a pain so I spend a couple of dollars and get it done on one big sheet of paper. Cheap and easy.
  9. HockeyPop98
    HockeyPop98 Tele-Holic
    Ohio
    Cheap and Easy! I found my new motto!
  10. Tear
    Tear TDPRI Member
    Columbus, OH
    i work at a print company and actually used a guitar template to calibrate one of our presses! ...... as long as you print it at the original size ,assuming the pdf is correct you shouldn't have a problem ...... i bought the cheapest printer walmart had 3 yrs ago and it still has an accurate output.
  11. RickyRicardo
    Calgary, Alberta
    If only this hobby was like that...:lol:
  12. Chordophonic
    Isle of Wight UK
    If only!
