Princeton sounding Pitiful
Discussion in 'Amp Central Station' started by Tele-Belly64, Nov 14, 2019.
  1. Tele-Belly64
    Tele-Belly64 TDPRI Member
    Aberdeen, Mississippi
    Last nite i was putting a new pedalboard together to feed to my Princeton Reissue, got ready for my traditional A minor chord strum and the sound was way of, getting no umph out of it, so i was checking all my patches and running over things of that nature, increased volume to about 5 or 6 and still no sound, went back to the think tank and i wound up searching for my buffer, threw it at the beginning of the chain and the volume issue was alleviated, then i broke out my verb/vibrato switch and when i turned the vibrato on it sounded like squat, i mean like a flat tire, literally the amp sounded like it was rattling out of control when i got it to about 5 or 6 on this dial, anybody out there got an idea or possible solution? Thanks for any advice, Later
  2. archetype
    archetype Fiend of Leo's
    Williamsville NY
    Plug straight into the amp and tell us what that sounds like. Troubleshoot outward from there, one device at a time.
  3. Tele-Belly64
    When you start dialing in the speed dial at about 5 it sounds like a helicopter taking off, only from the speed dial tho, the intensity can be dimed and no adverse reaction
  4. dogmeat
    dogmeat Tele-Afflicted
    Alaska
    get the tubes checked
    McGlamRock likes this.
  5. King Fan
    King Fan Friend of Leo's
    Salt Lake City
    Yep, maybe start by swapping a known-good 12AX7 into V4, and if no better maybe into V3?
  6. Peegoo
    Peegoo Tele-Meister
    Motorboating! Putt putt putt putt putt
  7. Tele-Belly64
    I'd say that could very well be happening with what i am hearing, it's a very predominant noise with a distinct seperation from pulse to pulse, the amp is only a couple months old and this is the first time i plugged in verb/vibrato switch, frustration has ensued, i am just Hoping i haven't damaged it too much, sounds like butter every other which-a-way
