Princeton Reverb sized power transformer with more than 100ma current?
Discussion in 'Shock Brother's DIY Amps' started by tubedood, Jun 6, 2021.
  1. tubedood
    tubedood Tele-Holic
    Orlando
    Hi again!
    Needing to replace a 300-0-300 or (330-0-330) Weber W022772 100ma Princeton tranny that gave up the ghost.
    I'd like to up the current capacity on the HV to 144-175ma but I cant seem to find anything that will fit the cutout without cutting and drilling.
    Anyone come across such a transformer? I don't need the 5v taps as I am using SS rectifier.
    Tube complement is 3 12AX7's and 2 6V6GT.
  2. tubedood
    tubedood Tele-Holic
    Orlando
    Looks like I found one! Amp Parts Direct... APD200H.
    310-0-310 @ 150mA
    6.3v @ 4.5A
    5v @2A
    Any others come to mind?
    King Fan likes this.
  3. 2L man
    2L man Tele-Holic
    Finland
    If you change to a bridge rectifier you don't need a CT transformer and perhaps find it easier
    tubedood likes this.
  4. tubedood
    tubedood Tele-Holic
    Orlando
    Good idea thank you!
  5. tubeToaster
    tubeToaster Tele-Meister
    Brentwood,Tn.
    Hammond 290CAX has 115ma. A little better than stock.
    Allen Amps TP25H has 150ma but he is not selling transformers at the moment due to supply chain problems. You might check with him to see when he will start selling them again.
  6. monkeybanana
    monkeybanana Tele-Holic
    mmhmm
    I emailed him a couple weeks ago and he said he doesn’t know when or if he will sell again due to losing two winders.
  7. schmee
    I used a Hammond Vibrolux tranny 325-325, plenty of power too. 125 ma. For some reason it was cheaper than a PR transformer from them... go figure...
  8. 72_Custom
    72_Custom Tele-Meister
    Pittsburgh
    I recently stumbled upon the fact that a Hammond 272DX standup transformer will fit a typical Princeton/Champ PT cutout. 300-0-300 and 144mA. Mounting holes line up perfectly. The cable egress does come close to the edge of cutout, so they may pinch if one is not careful. A small nibble would help or a strategically placed rubber washer. But it can work without modification.
