Princeton Reverb - Reverb Hum
UncleChewy
I just picked up a used 2017 68 Custom Princeton Reverb (all tube) and noticed on the second day that a hum appears when the reverb is turned on and gets louder as the reverb is turned up. The hum disappears completely when the reverb is turned off.
I'll skip ahead and say I just replaced the spring tank with a new one hoping that would get rid of the hum, which it didn't, but did manage to reduce it by about 80%.. which is great. I'm wondering maybe there's a ground issue elsewhere causing the hum, cause I'd like to get rid of it completely if I can.
I guess my question here is.. Should it be possible to eliminate this hum? Or is it normal for the reverb to cause a little bit of hum? And yes.. it still gets louder when as the reverb is turned up?
Willie Johnson
Chicagoland
Interesting..I'll look into that.
Would you say your reverb is pretty much silent now? Even on 10?
Thanks
It was pretty quiet after that--before that it had a weird sympathetic ringing as you turned the knob up past 5 or 6. You do get a little more hiss the more you turn up, but nothing abnormal. It's guitar equipment--it's never going to be stone silent.
UncleChewy
Fair enough.. In a perfect world I'd love to line my amp up with 10 other princeton reverbs and compare them, but right now I'm pretty happy that replacing the spring tank has made things much quieter than they were. This is my first all-tube amp in some years and I guess I just wasn't sure what I should expect for noise. I appreciate your response.. thanks again.
UncleChewy
Went to the local music store today and checked out the same amp they had on display and was pleased to find the same noise from the reverb that I experience from mine. Good to know I guess. If/when I really need silent reverb, my Strymon Flint pedal does the trick.
SoK66
Four Corners USA
There’s something of a compromise between production efficiency and noise in Fender’s PCB amp designs. I have what started out to be an absurdly noisy new ‘68 Custom Deluxe Reverb. After recapping the amp, removing the heater circuit and power section grounds from the PCB completely, changing the NFB resistor and eliminating reverb / trem from the “Custom” channel it’s now the quietest I can make it. IOW, I can’t hear it at idle if I’m in another room in the house. But side by side with my vintage BFDR it’s still noisy. It does sound quite good so I’m satisfied to just enjoy it as it is.
slider313
NC
Just a thought: I wonder if the old style shielded reverb cables would help?
fretknot
Murphy, NC
I agree, there are options for tweaking this amp to make it quieter and sweeter. I did some tube rolling with NOS valves and it made a big difference. Lower mu valves reduced the gain and tamed the reverb. That transformed the beast into a glorious tone machine.
