Princeton Reverb - Extension Cab
Discussion in 'Amp Central Station' started by Axegrinder77, Nov 4, 2019.
  1. Whatizitman
    Whatizitman Friend of Leo's
    WV
    8 ohm 1x12 cabs are actually the most common. Some of them are pretty cheap. Fender has a cab for the XD head, $199 new. There are lots of cheaper ones from other brands.
    Leave the internal speaker plugged in. Plug an 8ohm cab into the ext speaker jack. That’s 4ohm load (if it’s a RI princeton, that is).
    Axegrinder77 likes this.
  2. knockeduptele
    knockeduptele Tele-Holic
    London
    it is certainly louder by a huge factor but perhaps not as toneful
    the other trick if you want it to be a bit bigger and rounder is to go for an open back 2x12 cab but load it with a 10 and a 12 - wire an 8 ohm 10" in series with the combo and then put a 16 ohm 12" in parallel across it to bring it back to 8 ohms - seems to move a bit more air and go lower - it is actually possible to do it on a stereo jack for an extension socket so its a single link lead from the amp with a 4 way speakon on the cab but meter at every stage as expensive mistakes can be made
  3. Telebellycut
    Telebellycut TDPRI Member
    Athens, GA
    If it’s any consolation, I also have a 68 deluxe reissue and it is beastly. I mostly use the Princeton for recording and practicing but I use the deluxe live. They’re both great but the deluxe stays clean when I’m playing with my band. I don’t think I could sell either one.
    jimash and Axegrinder77 like this.
  4. Axegrinder77
    Axegrinder77 Tele-Afflicted Ad Free Member
    Springtown
    I might just try the ramrod before any other moves. Doesn't hurt to have a couple speaker options kicking around anyways. Luckily I don't really need any more headroom at the moment. Just looking for a bit "bigger" of a sound, if that makes any sense.
  5. 69ChevyP/U
    69ChevyP/U TDPRI Member
    pacific nw
    2x10 Avatar cab w Jensen C10N speakers over here.. Made the PR sound twice as big and fills the room much better.
  6. 69ChevyP/U
    pacific nw
  7. zook
    zook Friend of Leo's
    Cochise, AZ
    I put a 12" Eminence legend 1258 in this one. I sounded great.
    69ChevyP/U likes this.
  8. Axegrinder77
    Springtown
  9. 69ChevyP/U
    pacific nw
    Just the cab..
  10. KC
    KC Friend of Leo's
    Missoula, Montana
    Yes it does!
    zook likes this.
  11. jimash
    jimash Friend of Leo's
    NJ
    I frequently play my CPR through a 1/12 closed cab with an EVM 12 in it. That works. I am actually afraid to plug in both .
    But I do also have a Mesa Boogie Subway Blues, and those two sound good together.
    Sometimes I use the VibroChamp XD as an effects amp with the CPR and pretend its a Rover.
  12. Rooster-p
    Rooster-p TDPRI Member
    I have a 68 princeton ri I just bought and I just happened to catch this post, I know it's old but to answer your question it must see a minimum of 8 ohms so the best way to accomplish this is to unhook the existing 8 ohm 10" speaker and replace it with a 16 ohm 10" speaker in the amp itself and plug a 12" 16 ohm extension speaker cab into the other 1/4" speaker Jack and that gives you your 8 ohm minimum. That is the absolute safest way to do it. Either that or replace the 8 ohm 10"speaker with a 8 ohm 12" speaker in the amp cab baffle or the only other way would be just unplug your 10" speaker in the amp and just plug your 8 ohm 12" extension cab in it's place and make sure you plug it in the same place as the 10" amp speaker was and your good to go. That would be your cheapest and easiest way to go but I think I'm gonna replace the 10" with a 12" 8 ohm UK made greenback, can't go wrong there. So there's your answer without a doubt, do not go below 8 ohm's. There you have it.
  13. Rooster-p
    I know this is an old thread but I gonna try anyway. When you put the 12" speaker in your princeton did you cut your baffle out bigger or replace the baffle or was you able to put it on the existing baffle without any changes?
  14. Rooster-p
    minimum load on a 68 princeton RI is 8 ohms. It will work at 16 but it will be less clean headroom. The manual definitely says 8 ohms minimum so I wouldn't go to 4. You'll be makin bacon on your tranny.
  15. zook
    Cochise, AZ
    I actually built the cabinet. The speaker baffle as designed to accommodate the 12.
    That being said, the original baffle can be modified to fit a 12. That's what Randall Smith did when he first started building what became the first Boogie amps.
    Rooster-p likes this.
