Just cuz I like drawing in DIYLC, and really like Doug's external-adjust bias pot in my Princeton Reverb and similar amps, I offer this. Any errors are mine, not his.
Doug's classic diagram (his link here has helpful notes):
My DIYLC:
Details: The pot can go in a hole drilled near the bias board, or in an empty hole (I used the ground hole in the back panel), or mounted bushing-up (see wiring note) for internal adjustment. Since the pot requires a skinny screwdriver to adjust (and the slot is set well back in the bushing) there's no risk someone will give it a curious twist. OK, I have seen someone try to plug in a cable, but, um, nothing happened.
Doug's 27K tail resistor often seems to work nicely in a PR; in amps like the 6G2 and 5F11, a smaller resistor (15-22K?) is sometimes needed to center the bias range. And note the 100K resistor here is a bigger, 'knockdown' resistor for the high voltage from the rectifier -- if you have a ~50V bias tap, you need to downsize.
My DIYLC:
