Previous owner glued the speaker wires to the speaker.
Discussion in 'Amp Central Station' started by yahooer21, Oct 10, 2017.
  1. yahooer21
    yahooer21 TDPRI Member
    Nova Scotia
    The previous owner of my 1971 Fender Super Reverb seems to have glued the speaker wires to the terminals on the speaker preventing any of the speakers from being disconnected. One of the speakers has also been forcefully disconnected, meaning the wire came loose from the metal connector causing it to be difficult to reconnect. Any tips on removing glue from these metal surfaces?
  2. Dacious
    Dacious Poster Extraordinaire
    Godzone
    If they're superglued, you can try a drop of acetone. Also a heat gun if he's used some sort of hotmelt glue. A soldering iron may work, too.
    nojazzhere likes this.
  3. nojazzhere
    Foat Wuth, Texas
    Plumber's torch?...VERY CAREFULLY......
  4. TeleFunk Man
    TeleFunk Man Tele-Afflicted
    Gatineau, Québec, CANADA
    You may want to cover the exposed speaker cone in case the glue drips.
    Tomm Williams and JustABluesGuy like this.
  5. Ringo
    Ringo Poster Extraordinaire
    Memphis TN
    pics? removal depends on what kind of glue was used, if it's CA aka Superglue, you probably can just scrape it off, cured CA turns to plastic.
    If it's silicone or elmers, I don't know what to suggest.
    I've never heard of gluing wires to speaker terminals, guess that goes in the "there I fixed it " files.
  6. Tomm Williams
    Tomm Williams Tele-Afflicted
    He was out of duct tape
  7. drf64
    drf64 Poster Extraordinaire Silver Supporter
    Ada, MI
    it happens. His wire was falling off the terminal. instead of doing the correct procedure and crimping the connection he screwed you over.
  8. yahooer21
    Nova Scotia
    Here are some close-up pics of the wires, its hard to see but there is some sort of yellow residue on the terminals.
    The amp is far from original, at some point it was housed in a new cabinet, the baffle and wiring harness are aftermarket. These are original Emminence speakers.
  9. hopdybob
    hopdybob Tele-Holic
    netherlands
    you have a second lug on that connection, why do you don 't use that?
  10. Ringo
    Memphis TN
    yep what he said, just put some new clips on the wires and use the other set of speaker lugs , I can't tell for sure but it kinda looks like the other clips are soldered onto the speaker lugs?
  11. yahooer21
    Nova Scotia
    It's actually possible the clips are soldered on to the lugs and the yellow stuff is crud or corrosion-the clips are not moving at all even after a treatment with acetone. Looks like i'll have to use the other speaker lugs. Thanks all!
  12. crossroader
    crossroader Tele-Afflicted
    Endicott, NY
    Yep - clip the old wires off and use those clean connections on the 2nd tab.
    I'm not sure I'm seeing glue - looks like old solder flux and some corrosion, to me. They may have been crimped AND soldered. That would certainly make for a solid connection.
    I would just use the alternate tabs on those.
  13. noah330
    noah330 Friend of Leo's
    Maryland
    Heat them up with a soldering iron and see what happens or just use the other lugs.
  14. yahooer21
    Nova Scotia
    The speakers themselves are not the cleanest-there is corrosion on the backs and the speaker domes have been pushed in or dented-so i'm not bothered with leaving the old clips in place and attaching new clips to the second lugs. Either way i'm taking the amp to a tech at the end of the month for a checkup, so i'm not too concerned with making it perfect as long as its safe.
  15. Mutato
    Mutato Tele-Meister
    Rhode Island
    That def looks like solder residue to me as well.
    ecosse likes this.
  16. Ringo
    Memphis TN
    The corrosion on the speaker frames isn't really a big deal , neither are dents in the dust covers.
    As long as the speakers sound good that's all that matters.
    alnicopu likes this.
  17. Flyinlow
    Flyinlow Tele-Meister
    NE Indiana
    I'd get it hot with a soldering iron, and see what it does.
  18. Frodebro
    Seattle
    Those are definitely soldered on. The correct way to deal with it would be a soldering iron and a solder sucker, followed by desoldering braid.
  19. charlie chitlin
    Spring City, Pa
    Soldered.
    It's good insurance.
    Knock a push-on spade terminal off with the power cord or vibrato/reverb pedal and you could fry your OT when you turn the amp on.
    I solder them.
    aerhed likes this.
