Preserving Autographs
Discussion in 'Bad Dog Cafe' started by garytelecastor, Oct 10, 2014.
  1. garytelecastor
    garytelecastor Poster Extraordinaire
    On the Bayou in da Tundra
    I have several guitars with autographs on them of people I have played with. I would like to be able to keep them rather than letting them wear away.
    Is there any way I can cover them and still use the guitars they are on?
    I searched here for a thread that might have answers and I couldn't find one, but if it has been posted let me know.
    thank you.
  2. Jimmyspaz
    Jimmyspaz Tele-Holic
    Auburn Ontario
    A clear coat of whatever the guitar is finished in (lacquer, poly, etc.)???
  3. brenn
    brenn Tele-Afflicted
    Kentucky
    Problem is, the solvent in the clear coat will likely destroy the autograph as soon as it's sprayed on.
  4. TeleTex82
    TeleTex82 Friend of Leo's
    Out there
    Woodburn them in?
  5. Jupiter
    Jupiter Telefied Ad Free Member
    Osaka, Japan
    Yep, tricky, unless you know what it was written with. In that case you could test it....
    Second best might be to get a bunch of pens and do a test by writing a bunch a sigs and then seeing what type of clear messes with 'em the least.
  6. goldtopper
    goldtopper Friend of Leo's
    Liberal Lakes
    1/4" coat of poly should do it.
  7. 62 Jazzmaster
    62 Jazzmaster Friend of Leo's
    Steveston BC, Canada
    I wondered the same thing with the autograph on my Teisco TRG-2L, but never was brave enough to spray anything on it. I'm just careful to avoid rubbing my arm against it. It's mostly a wall-hanger now. :neutral:
  8. telleutelleme
    telleutelleme Telefied Silver Supporter
    Houston
    Use a piece of clear Mylar like they cover pick guards with. That stuff is almost impossible to remove. I've bought it at fabric stores and used it as a table cloth to protect the wood finish on a dining room table. Sticks pretty good without glue or anything.
  9. Jupiter
    Osaka, Japan
    Sort of a shame; that thing should be out blasting Klingons every night....
  10. garytelecastor
    This is my problem. On my B Bender I have 4 , on my 77 I have about 20+. I don't take the 77 out anymore, but I would like to use the B bender. I am going to give the mylar a try.
    Thanks again, you guys. I appreciate your input. -g
  11. Jon C
    Jon C Tele-Meister
    Mid-Atlantic USA
    Not necessarily.
    I over sprayed a Will Ray Sharpie signature on the back lower bout of my G&L ASAT Special (he signed at a clinic before I bought it from the dealer) with 3-4 light coats of poly (guitar ReRanch iirc but I'm not sure, it was several yrs ago). The G&L finish is poly. No issues at all, I wet sanded carefully with 400-600 grit and it looks like a factory finish w the sig preserved. Ymmv, as they say.
    I'd worry about Mylar yellowing, etc., over time.
  12. PennyCentury
    PennyCentury Poster Extraordinaire
    New Hampshire
    Check with the art people at your local Michaels or A C Moore; the protocol is usually spray fixative then polyurethane (match gloss to rest of guitar body).
  13. garytelecastor
    Thanks Penny. Looks like Mon is filling up.
