Preferred OD pedal with a bit more drive than a Klon Cone
Discussion in 'Pedal/Effects Owners Clubs' started by Cali Dude, Aug 30, 2020.
  1. vintageampz
    vintageampz Tele-Meister
    Orange County and San Diego County
    There is NO BETTER Tube Screamer (OD) pedal than the "Green" Ibanez pedals of yor (Old).
    Whether it's an original, mid life or accurate reissuse in a new case still:
    The ONLY thing that is equal, maybe even a bit better, is the one that started it all, an original 1978 hand wired "breadboard" "ProCo Rat" that was made in the companies Kalamazoo MI garage. Called "Distortion", it was really an Over Drive.
  2. beninma
    beninma Friend of Leo's
    Earth
    It's mostly cause this is non-trivial to get right and the answers are never that helpful considering the # of variables that affect the choices.
    It's always:
    " I like this pedal... " and then the person writing the answer doesn't include "for my rig which has a different guitar and different amp than you!".
    It doesn't help that so often the person asking the question doesn't bother to include details on their guitar + amp combo.
    Cali Dude, blowtorch and MilwMark like this.
  3. beninma
    Earth
    I think you can never really answer this question without knowing:
    - What is the guitar? (Though I think this is actually not always critical unless maybe comparing single coil vs humbucker)
    - What is the amp?
    - What kind of EQ response does the amp have? (Scoopy American? Tweed? Mid-heavy British? Does it have excessive bass?)
    - Are you trying to use the pedal to get dirt in front of the amp clean?
    - Are you trying to use the pedal to boost the amp on the edge?
    - Are you trying to use the pedal to tighten up the amp setup in a fully saturated high gain config?
    The threads about Overdrives are so bad it's taken me years personally to get a handle on it.
    If you get a Fender blackface amp that seems to be the shortcut... so many people have that kind of amp that the random recommendations have the best chance of working if you have a blackface amp.
    If the Amp has a scooped EQ tone:
    - Mid Focused or flat drives if the amp is clean, avoid scooped EQ drives
    - If the amp is on the edge Mid focused or flat can work
    - If it's cranked mid focused is probably better
    If the amp has lots of mids:
    - Flat EQ drives will work better if the amp is clean, avoid mid focused
    - If the amp is on the edge either can work
    - If the amp is cranked stick with mid focused
    That's my impression.
    chris m., Cali Dude and MilwMark like this.
  4. Daddy Hojo
    Daddy Hojo Friend of Leo's
    Kentucky
    Caline Orange Burst (BB Preamp)
    Caline Pure Sky (Timmy)
    Joyo Sweet Baby (Mad Professor Sweet Honey)
    Each of these are around $30 - try them all or even combine a few. They all stack nicely.
    kevsonic, Rocky058 and Cali Dude like this.
  5. Cali Dude
    Cali Dude Tele-Holic
    California
    Thanks, I have had a TS9 for 28 years. I used it a lot for a good decade, but don't like how it covers the natural sound of the guitar especially, and the amp for that matter. I appreciate the suggestion.
  6. Cali Dude
    California
    Good point. My goal is to get anything from 60s blues rock 70s to 80s rock sounds. I run different amps depending upon the situation. I actually stated this earlier in the thread. THD bivalve outside gigs, or DRRI or tweed Harvard indoor gigs. Run amps to breakup, and clean up with volume, extra OD with Archer, and fuzz with Lovepedal 200lbs. Idea was for OD pedal with more drive than Archer. Thanks for taking the time to read this.
  7. Cali Dude
    California
    Thanks for the great reply. I gave some of the info on #86 post. Always running amps at breakup, and clean up with the volume controls of guitars. Guitars are USA Hamersunburst with Lollar Imperial HBs, USA signature Buddy Guy strat(lace gold with 25db midboost), or G&L Asat Z-3. Playing 60s blues rock,70s-80s rock and some country. Amps : THD bivalve, or DRRI or tweed harvard for smaller gigs. Often use attenuators. Thanks for taking the time to read this.
  8. beninma
    Earth
    My guess is you might need two pedals and maybe the stack approach would work?
    Are you trying to build one pedal board that can work with all combinations of your amps + guitars?
    The DRRI is mid-scooped, the Tweed Harvard is not right? And the Bi-Valve is a chameleon that can be a bunch of different things?
    I'd probably look for one pedal that is mid-focused and one that's flat or scooped and then adjust the knobs depending on which amp you're hooking up.
    Cali Dude and chris m. like this.
  9. chris m.
    Santa Barbara, California
    I agree two pedals are better than one. You can use one pedal, the other pedal, or both together. Of course, there are two-in-one pedals like Jekyll/Hyde that can give you two sounds. One downside to a two-in-one is usually the pedal order is fixed. If they are separate pedals you have the option of changing the pedal order depending on the amp you are using. In my experience when stacking pedals the dominant tone is whichever pedal is closest to the amp. So if you have a mid-focused amp and a mid-scooped amp, you might put the mid-hump pedal last in the chain when using your mid-scooped amp, and you might try the more neutral EQ drive pedal last in the chain if you are using your mid focused amp.
    Cali Dude likes this.
  10. Strebs
    Strebs Tele-Meister
    NE Texas
    This little yellow drive is pretty amazing and affordable.
    DOD Preamp 250
    kevsonic and Cali Dude like this.
  11. hj ayala
    hj ayala NEW MEMBER!
    39 Rue Du Lazaret
    HI.
    IF YOU LIKE your sound, & you are just looking for more girt, put a booster before your Klone. It's sounds amazing.
  12. Cali Dude
    California
    So get 2 Klon clones? What do you use?
  13. eclecticsynergy
    eclecticsynergy Friend of Leo's
    Albany NY
    I'm a huge Lovepedal fan. I'd say the Box Of Awesome might be the ticket here.
    Kalamazoo side has more gain than a klone but offers a similar character and cut. Has the Glass treble boost plus a regular Tone; this allows very responsive fine tuning of your highs.
    OD11 side delivers boost/grit/grind without altering the overall voicing much (although it also offers Low and High tone knobs).
    Two sides, each great on their own and downright epic when combined.
    There's an order switch to allow choosing which comes first in line.
    Importantly, like the 200lbs Of Gold, the BOA sounds great through many different amps.
    And it stacks incredibly well with any pedals I've tried it into.
    I would part with all my other OD pedals before giving up the BOA.
  14. PastorJay
    PastorJay Tele-Afflicted
    California
    Having read through all your posts, what sound youre looking for, amps youre using, etc,
    I think there are several things that might make sense, to stack with your clone
    some of these I suggested before.
    Rat style. I like the Mudhoney YMMV
    Boss SD-1, assymetrical whatever that means clipping makes it brighter than a TS, which I like for leads but not rhythm YMMV
    another clone
    Timmy --doesn't color the tone much
    EP boost
    A Marshall in a box pedal
    which one would do it for you?
    You never know until you try
    good luck
    Askwhy and Cali Dude like this.
  15. pippoman
    pippoman Tele-Meister
    Memphis
    Petty John Iron. Overpriced I guess, but it floats my boat.
  16. Cali Dude
    California
    Cool, thanks. I will check it out.
  17. kevsonic
    kevsonic Tele-Meister
    Philadelphia, PA
    I'm late, but the Tone Nation by Big Knob Pedals is klon-based, but to my ears higher gain.
  18. kevsonic
    Philadelphia, PA
    I'm glad I'm not the only one noticing it! Plus the "guitar+cord+amp" comment on page 3 of a thread in the Pedal Effects Owner's Club. Priceless stuff!
  19. Roman4405
    Roman4405 Tele-Meister
    VA
    I’m sure someone’s recommended it already but the Morning Glory is probably my all time favorite low-medium gain OD pedal. Just sounds great and works well with humbuckers and single coils.
  20. PixMix
    PixMix Tele-Holic
    MI
    Boss SD-1 Waza Craft or just the regular one stacks really well with the archer. I have both (and an Archer), the SD-1 Waza Craft gives you another voicing (Custom?) besides the Standard and is a less noisy than the regular SD-1. They both go from almost a clean boost to growl, with SD-1w having an even wider range when switched to a C mode.
    kevsonic likes this.
