Scooby9261
I have a tester for 6L6 type tubes. But im looking for a relatively cheap priced tube tester that tests preamp tubes. Curious what you all would suggest.
Funny enough, I picked up an emission tester a couple weeks ago, and it just tells me every tube is good, even known-bad onesA tester can tell you if a tube is bad - it can't tell you if a tube is good.
Funny enough, I picked up an emission tester a couple weeks ago, and it just tells me every tube is good, even known-bad ones![]()
Excess noise, crackles, etc... that follow the tube. Thanks for taking the time to write all that out! After my post yesterday I did a deeper dive into emission testers vs transconductance testers and spent an hour or so reading what you summarized so well. So I suppose a better choice of words would have been 'known-bad-in-a-particular-circuit'.“even known bad ones”…. What were the problems that established these ‘known bad tubes’ as being ‘bad’.
A lot of times those "noisy" tubes are great for tremolo circuit use. No need to discard them most times.Excess noise, crackles, etc... that follow the tube. Thanks for taking the time to write all that out! After my post yesterday I did a deeper dive into emission testers vs transconductance testers and spent an hour or so reading what you summarized so well. So I suppose a better choice of words would have been 'known-bad-in-a-particular-circuit'.
good to know, I'll try them out in my PRRI tremolo, thanks!!A lot of times those "noisy" tubes are great for tremolo circuit use. No need to discard them most times.
