Preamp, power and speaker breakup
Discussion in 'Amp Central Station' started by Mark the Moose, Jan 17, 2020.
  1. Mark the Moose
    Mark the Moose Tele-Holic
    Erie, CO
    I've been able to experiment with preamp vs power amp breakup, but I'm can't find any recordings that isolate speaker breakup. Some people seem to dig it, others not so much...but I can't seem to figure out what "it" is!
  2. printer2
    Check out some modeling amp simulations online. I seem to remember (heck, maybe I dreamed it) coming across a site.
  3. schmee
    Speaker breakup needs a lot of volume, of course depending on the speaker. The cone goes into random shapes wildly producing inaccurate sound, ovalizing the voice coil maybe. The other type is "Float compression" where the cone stays reasonable shape and kind of floats sustained on the notes suspended by the magnetic force.
    Old Tweed bassmans with the P10R's would do that. But man, you are loud when it occurs. (re: Albert Collins)
    Speaker "good" distortion is very hard to get and control in a live situation, a fine line, unless volume is no problem.
    Amp size is easier.
    Preamp...hmmm.. maybe easier yet.
  4. Mexitele Blues
    Mexitele Blues Tele-Holic
    Westminster, CO
    My Gibsonette produces what I believe to be speaker breakup at about 3:00 and higher on the volume knob. It's rather unpleasant, sounding like fizz through a wrapping paper tube, with the tube length being modulated. Fortunately the amp sounds best between 9-1:00. I would think that similar old, low wattage alnico speakers would be easiest to break up if you want to try.
    Crashbelt likes this.
  5. printer2
    Something like this looks fun.
  6. arlum
    arlum Tele-Meister Gold Supporter
    O'Fallon, MO
    Listen to a cranked Vox AC 30 into a pair of 15 watt Celestion Alnico Blues. This amp with these speakers taught me how much speaker breakup can play a roll in an amplifiers tone.
  7. trxx
    trxx Tele-Holic
    Between reality and imagination
    I have a Weber that sounded glorious with a DSL50 before I 'broke it up' too much. :p It's going to need a recone.
  8. 1300 E Valencia
    Fullerton CA
    First, as arlum has pointed out above, do not let your life pass by without playing an AC-30 with AlNiCo Blues. It is a religious experience.
    The short answer is, if you want *less* speaker breakup, get a speaker with a much higher power rating than the amp. Generally, you'd want a speaker with twice the capacity of the amp, i.e., a 100 watt speaker for a 50 watt amp.
    In the same amp, a 300 watt speaker should be cleaner. Ideally, any distortion would come from turning up the amp, with little, if any, added by the speaker. Whether this sounds good is a different question.
    Even then, most speakers for guitar as designed with breakup, distortion and color built in. Even that 300 watt EVM 12L. It's designed for guitar and its narrow range of frequencies, not hi-fi reproduction.
