Preamp help
Discussion in 'Amp Tech Center' started by Johnman, Jul 30, 2021.
  1. Johnman
    Johnman TDPRI Member
    Thibodaux
    Having issues with preamp voltages
  2. Jon Snell
    Jon Snell Tele-Holic
    Jurassic Coast. Great Britian.
    Hmm. I wonder what on.
    A schematic and description or list of voltages would help as there are many designs out there and we don't know which one you have chosen.
    Wally likes this.
  3. Johnman
    Thibodaux
    It’s a1968 Marshall superlead build
    Timbresmith1 likes this.
  4. Johnman
    Thibodaux
    V1
    Pin 1 229v
    Pin 2.1mv
    Pin 3 1.34v
    Pin 4 3.06v
    Pin 5 3.05v
    Pin 6 300v
    Pin 7 .04 mc
    Pin 8 0
    V2 pin 1 418v
    Pin 2 .4 mv
    Pin 3 418.8v
    Pin 4 3.10v
    Pin 5 3.10v
    Pin 6 423v
    Pin 7 423v
    Pin 8 423v
    V3
    Pin 1 446v
    Pin 2 373v
    Pin 4 3.11v
    Pin 5 3.11v
    Pin 6 443v
    Pin 7 373v
    Pin 8 419v
  5. Jon Snell
    V2 doesn't look at all right.
    Firstly a bit of history since 1959;
    The cathodes of the valves must sit no more than 3volts above the grids and the grids of V1 and the first half of V2 must be around zero volts. The second half of V2 has a grid voltage of between 100 and 200volts as does the cathode.
    V3 is off as well!
    If this is a Marshall amplifier and has just gone wrong, look for burnt resistors caused by faulty valves.
    If home made, check your work.
  6. Johnman
    Thibodaux
    V1
    Pin 1 210v
    Pin 0v
    Pin 3 1.24v
    Pin 4 3.06v
    Pin 5 3.05v
    Pin 6 274v
    Pin 7 0v
    Pin 8 2.29v
    Pin 9 3.10v
    V2 pin 1 105.6v
    Pin 2 .004v
    Pin 3 49v
    Pin 4 3.10v
    Pin 5 3.10v
    Pin 6 108.6v
    Pin 7 108.7v
    Pin 8 108.5v
    Pin 9 3.1v
    V3
    Pin 1 269v
    Pin 2 29v
    Pin 3 47.8v
    Pin 4 3.11v
    Pin 5 3.11v
    Pin 6 266v
    Pin 7 31..5v
    Pin 8 47v
    Pin 9 3.05v
    I had a missing ground and this is the voltages as of right after soldering the missing ground for v2
  7. Jesco
    Jesco TDPRI Member
    Oakland
    V2 pin 3, 6, 7, 8 still look off. I would double/triple check your wiring.
  8. Wally
  9. Johnman
    Thibodaux
    If I wanna have more bias current adjustment what should I do?
  10. Wally
    So you got the preamp and PI straightened out? What are your V2 voltages now? What about V3?
  11. 2L man
    2L man Tele-Holic
    Finland
    Schematic above is impossible to read but if you want higher bias current, reduce the resistor value which is drawn above adjust potentiometer.
