Lowerleftcoast
Good to hear!PROBLEM SOLVED!!! This is what I did:
I had a look at the the picture on the build journal. To continue with the tutorial with ground scheme practices...
I noticed the orange wire from the PT is connected with the other grounds (ground bus) on the terminal strip. I presume the orange wire is the shield wire for the PT. If it is indeed a shield wire, it should be connected to the chassis. The orange wire does not have return current for the B+ so it should not be associated with the ground bus or any of the nodes. It is only a shield. No current.
