practice amp in 2025 ?
  • Thread starter brogh
brogh
Teleland
Going to pick up the ahem..."practice" amp in a couple of hours :D
thanks to all for the great suggestions !! this forum is always a great place :)
Cheers
AndrewG
Exeter, England
What sort of volume will you be practising at? If you're looking at neighbour and house-friendly levels the Roland Microcube might suit. These small amps are designed to sound good at low volumes, unlike most 'big' amps which are a practise/gig compromise and seldom sound good at low level, irrespective of attenuation. You may be able to find one of these; 2W, all valve, great reverb.
brogh
Teleland
What sort of volume will you be practising at? If you're looking at neighbour and house-friendly levels the Roland Microcube might suit. These small amps are designed to sound good at low volumes, unlike most 'big' amps which are a compromise. You may be able to find one of these; 2W, all valve, great reverb.
sorry :) already picked .. and I went WAAAAAAYYYYYYY over board
Playground
Scandinavia
For home practice I use either a Postitive Grid Spark 2, or two identical Vox Pathfinder 15Rs' that I usially run in a stereo/ping-pong setup (with a Nux Time core delay deluxe pedal mk.I).
I also have a few iOS apps that I sometimes use just with an ipad and a pair of headphones.
zeke54
central calif.
If you like British "chime" look for a Vox AC4. No master volume though. For a basic head, the Bugera T5 is great. It has 1/4 watt, 1 watt and 5 watt output options.
I second the vote for Bugera T5 . I've had mine about 15 years and it's not my only amp but I keep going back to it . It also has a power selector .
ChiTownJimbo
ChiTown
Howdy,
So I'm looking for a practice amp, I mean I'd.... love to have a 5e3 or a Jtm 45 but that might get too loud and pricey for home only use.
besides getting better I want to get out of the pc simulation thing, I want an amp that I turn on and play without any other distractions, I'm amp-less at the moment and play trough pc.
doesn't need to be new but no crappy stuff,
needs to have at least reverb,
master volume eventually depending on the amp
no boxy sounding amps,
no desktop amps,
no amp pedals,
tubes ? .. I'd love to but maybe not for this application..
Take it as a reference only: I've seen on YT Marshall JTM studio & Tone kink Falcon Grande, but those are real proper amps and to pricey for my pockets, but I love the sounds they produce.
What do you amp experts suggest ? I've stopped looking at gear and not up to speed, again the goal is get off the pc
Thanks !
2cents worth. **
Bugera v5, after a while you’re gonna want to push more air than the 8in, so you go get a 2x12 cab and a good cable, then you see a great deal on reverb and get a T5, then (if your back can handle the weight) you spring for the BC30 because it has the miss matched speakers AND the attenuation switch!
** then you see that tweed Carvin Sweet 16 1x12 sitting in the corner and forget about everything else that I just accumulated. Hahahahaha
Seriously though go and try every single thing you can there will be limitations in everything
groovemastergreg
Austintatious
For cheap, a recently discontinued roland micro tube will blow your mind. About $100 used. I’ve had mine 20 years. Tiny.
The Spark amps are great and have great preset sounds like the micro tube but need smartphone or iPad to get most out of it. Great tones and has a master volume so like an attenuator.
I love my Roland blues cube hot and prolly around $400+ used.
The newish champ reverb tube amp is great but getting up around $700 up used but it’s a loud six watts.
Dontownatele
Sea of Cheese
Tonex one pedal and a 5” studio monitor or a nano cortex… and a 5” studio monitor.
Seriously. Blows my mind. I love low watt tube amps too.
Caffiend
Avalon
There's a lot of questions to answer. If you want completely trouble free play and forget, your best bet is a bug type with headphones like the Mustang Micro and understand that the headphones that work well for this or working on your DAW may well not be ones you want to listen to general music with.
Once into actual amps amps, number one question is headphones or speakers and after answering 'speakers' it really starts getting potentially weird and expensive. People will say 'just buy one with a master volume' but this is potentially misleading and possible a 'try not being a loser' type answer. Some MVs do work well, many don't and leave you with a very expensive bee-in-a-tin' type sound. Marshall Origins deserve a mention because while they definitely don't have useful MVs (the have pretty clean pre amps and make the good stuff in the power stage) they not only have a good sounding power reduction setup, they also have built in loads so you can actually disconnect the speaker for true silence and plug headphones or your DAW in to the emulated DI out. That output may well not drive headphones well without a little headphone amplifier (need not be expensive) but works really well. Although I accept the Origins have no built in fx at all.
Otherwise, you're into a game of finding out what you like in terms of combinations of amps, attenuators and load boxes. It's very much the case that all attenuation is not equal, and some will be happy with a cheap option while some may feel they need to drop 1k on an Ox Box. If you're thinking Fenders, then one of those bridges with volume knobs in the FX loopay be all you need (or indeed a simple volume pedal in the loop)
